Laptop boot error with logon? HELP?
|/3|\|0/|/|
US, Minnesota
Little long, but read through it :-/
I have a Dell XPS Studio 1645, and a month ago my screen was flashing funny on boot, and I could not log in. If I can remember, I think it froze or something funny before that. Never did that before. I powered down and booted in safe mode, and ran a restore to the last point, a week earlier. Worked perfect when booted normally and I thought nothing of it. Worked as it should since.
It has been about a month since the restore.
This morning I was doing some work, and everything was okay, nothing new installed or anything to mess with it. Powered down and went to my place. I turned it on again at home..and here is what I am having issues with.
It boots okay, loads windows, and when I am at my login splash screen with users and the password..It starts flashing the screen between black, and the windows 7 splash screen repeatedly. The cursor shows a loading symbol. There are no users to click on. Nothing happens but this "loading, and rapid flashing between normal and black" until I hold the power button down and kill it.
I unplugged the power cord and battery, put it back in, and tried again with the same result. The funny thing is I tried all safe modes, and they all work fine, 100% as they should. Internet, everything, all files and programs. I used command prompt to check and fix errors, and it found one. I saved and rebooted with those settings, and the exact thing happened again with no difference. :cry: Looks to have zero effect.
I am sure this is the same issue as happened a month ago, and I'd bet money I can fix it by system restore. The problem is that it will return again in a month, and I'll have the same problem. I heard it could be harddrive failure from a friend, but everything looks fine as I tested it, with no issues. What do I do? I need help because I don't really want to restore and have it happen anymore than the one time it has.
Any help is greatly appreciated, and thanks for your time :attn:
Try reinstalling your graphics driver. (download it from safe mode)
If that doesn't fix it...run a reparatory install of Windows.
I had to use it badly last night, so I set it back two days using system recovery from safe mode. Works like a boss again.
Hopefully it won't repeat the issue again tomorrow then lol
I am convinced either Windows update effed up the boot files, or the graphics driver randomly didn't decide to work. All I can say is I hope it doesn't randomly happen again, and until then, all is good.
lol wtf
