The CPU has unlocked power limits above the standard 253W, so it won't be much better. It's normal that it heats up so much. You can set standard power limits in the BIOS and check if everything works as well as you expect. If yes, then keep it like that. If not, then play some with power limits and the time when cores run at higher limits.
