- Dec 19, 2000
Ok obviously when we are cooling a CPU we try to get the largest fan, with the largest and highest output fan possible. But when we're trying to cool our video card's GPU, we can't really take the largest heatsink and the largest fan possible, at least not unless we want to block all of our PCI slots.
I'm trying to cool my Radeon GPU, but I can only afford to lose a single PCI slot (stuff is in all the others). Right now I have attached a rather large heatsink (from a graphics standpoint) cut from an old Slot 1 CoolerMaster. I'd say the heatsink is about 15mm tall, with a 10mm fan attached. At a combined size of 25mms this HSF combo just barely fits with some extra air flow room between it and the 2nd PCI card.
Now, the question here is, the fan only moves something like 10 cfm of air. Is it better to have this rather large 15mm heatsink, and a fan moving 10 cfm of air, or do you think it would be better to get a smaller 5mm heatsink and a 20mm thick fan which can move 19 cfm of air? I can really see both sides of this argument, actually, since a larger heatsink exposes more heat to be removed by the fan, but a larger fan can blow away more heat.
I'm not sure I'll change my cooler in any case, but I was just wondering what you guys think. Which is better, more air, or more metal?
(P.S. if I could spare the next PCI slot too, I'd just put a 15 mm tall * 60 mm heatsink and a 60*10mm Delta fan on it ;-) )
