Leak-Cleanup Advice?
RDWest2005
South Carolina
I'm making a new post cuz my post is way on down the page
my question...
now that i have it running
the DEX COOL antifreeze seems to have left a slick feeling film behind
the top of my top slot 7800 was soaked and i know it got into the pcie slot
I just called an electronics shop
they have SPRAY cans of 99% isopropal(me spelling is bad) alchohol
they said it evaperates pretty fast
should i spray into pcie slot and soak it and take air hose right quick and blow it out?
and spray the 7800 down real good?
i have just ordered DD UV Blue tubing so i have to take it apart 1 more time
so i want to clean up the film its left behind from leak
whats best way?
thanks
~RD
voigts
Tennessee
Ditto...bathe good, slot and all, in rubbing alcohol (probably want to take out the MB to do this) and put it in front of a fan overnight. The rubbing alcohol should be able to take care of the film from the coolant.
Janus67
Benching Team Leader
hmm, i may have had the same problem. I am gonna pick some up on the way home *sadface*.
