Led mod for the intake 9CM Enermax Fan
Vulpes
Denver, CO
I wanted to have a big fan in front of my case, also I want it to be adjustable, and finally I wanted leds!
I have bought a couple of enermax (they got 9CM fans (120mm wouldn’t fit in my case - bah!) and I drilled a hole in the front with the dremel tool (aluminum case made the job done easy) and I also drilled a circular hole on the front plastic bezel since it didn’t had any vent holes. That hole + leds would look pretty cool I thought, so I went ahead and purchased bunch of ultra bright leds from a guy, I bought 4 of blue red and yellow, and 3 of white, for other jobs. I have a soldering iron here and bunch of resistors (hey, my dad is ex-electrician, and its his hobby now) With my average soldering skills I put a 60 ohm resistor on each led, attached them to a old harddrive power connector and drilled 4.8cm (3/16 in.) holes in the fan. I took electrical tape and taped the leds in place (they were sticking out a bit, but didn’t touch the blades, because the holes were smaller than the leds). I then attached connector to power supply and fired it up. Looks very very nice.
And uh, sorry for blurey pics
Nice Job! very effective!!
Next job is for you to mod those LED's above your fan to match the colours you have in the fan!!! :D
I was thinking, since i have 2 blues 1 red and 1 yellow, i can leave blues as is, and hook up red to harddrive and yellow (the turbo) to the nic activity led, since its already modded.
I have 2 of those fans, so ill mod the other one, once a bigger case comes along ill just stick 2 of em up front :)
