Newby2OC (Apr 13, 2001 07:18 a.m.):
Steve (Apr 11, 2001 08:11 a.m.):
I have a FOP-32 and the noise although noticible isn't bad.... according to the specs the FOP-32 is about 38dBa and the WBK-38 or FOP-38 is about 43dBa.... just curious is this jump in the noise alot? I know this is really a tough question to answer on a bulliten board....
Thanks!!!
This is actually quite an easy question to answer from a point of view of sound increase, the rule is for ever increase of 3db you double the sound
i.e your FOP32 = 38db @ 41db it is twice as loud and @ 44db it is 4 times as loud (1x2)(x2) sound is logrithmic and increases expedentially.
now back to reality lets say for arguement sake that the fan you get is 41db even though it is only twice as loud, depending on the pitch it could sound loud or softer depending on your ears.
So the question isn't so much how loud is it, it should be what can I stand...
I came across a site earlier that actually gave you sample sounds of the different fans, if I can find it again I will post it....
There's some confusion here. 3 dB is NOT twice as loud. It requires double the electrical power into a speaker to get a 3 dB increase -- that's probably what you're confusing. I spent years hacking around as an audio junkie... Here's what I know:
1. One dB is inaudible for some people, but most can tell there's some subtle difference.
2. 2 dB is audible for most people, but not a big deal for many.
3. 3 dB is audible, and probably significant for most people.
4. 10 dB represents twice (or half) as loud (and requires 10 times the electrical power to produce in a loudspeaker -- ie, if 10watts gives you 90 dB, to get 100dB, you'd need to feed that same speaker 100watts.)
So to answer the original question, 5 dB is quite significant, very audible. It’s a big difference.
I have the YS Tech / FOP32-1and heard it compared with the Delta -- in 2 PCs, side by side. The YSTech is loud, to me, in a kind of rumbly, whiny way. The Delta just screams like a banshee. It is LOUD. No way I’d touch that sucker. It’s not just a volume difference – the high frequency output seems to be at the perfect 4kHz spot that irritates people to death.
I don't even use the YSTech on my FOP32-1 anymore, replaced it with an Everflow from a Volcano2. That’s a good fan (but Volcano2 is not a great cooler), quieter and “smoother” sounding with about the same airflow as the YSTech. I run it at 7v, like all my fans. Decided adequate cooling with low noise was preferable to great cooling in a factory zone.
