Hello,
I own a DVD/RW LG GSA-H42L SUPER MULTI LIGHTSCRIBE DVD REWRITER , and today i noticed something i have never seen before with my previews dvd or cd -rw .
When burning a cd or dvd , no matter what brand (i tried 3 different) i see symmetric circles on the dvds being created. Now what i mean with that.
I burned for example a dvd-r (also tried dvd+r) without multisession, and lets say like about for every 1000mb i see rings be created. So i got a ring for the 1000mb , a second ring for the 2000mb and so on, The point is that as we go to the outer side of the dvd, the rings fade out slowly.
As higher the speed is , as many rings i see being created. For example with a 4x i see only 2 rings being created on a dvd.
Although, the dvd as also the cds are burned succesfully on every speed.
Firstly i thought it could be the software, so i used something else and not nero, but the same. Then i thought it could be the os, so i tried under linux. but i had exactly the same results. I wanted to check for errors from the nero tools. but my drive is not supporter for an error check.
As i see this. it looks like it burns with a stronger laser beam on low speeds, and as it speeds up from 4x to 8x slowly, and from 8x to 12x... the laser beam also gets weaker thats why i get also those kind of circles created.
As i said, i am kind of confused as i dont know if this is something normal, or not and i should better return this product. I got the advice of doing a firmware upgrade , but i dont want to do that as i lose my guarantee.
For that reason , i am here to ask you, and year your opinions if thats something i shouldnt worry about. It's just something i never saw before all those years i burn cds and dvds thats why i thought posting.
Thank you in advance.
