Lian Li cases, front panel, and cd drives...
I.M.O.G.
Glorious Leader
Rootstown, OH
What do owners of lian li cases typically do for the cd drives to get them to match their case? Do they just buy black drives, or mod them?
subconcept
Toronto, Canada
You can buy aluminum face plates for floppy and cd drives, check on the lian li site to see if they make them for your cdroms.
For me I just painted mine, havent done the floppy tho.
This was done with tremclad aluminum coloured paint.
mateo
What I plan to do when I get around to modding my blue PC-60 is cutting out the tray cover from the panel using a 1/32" milling bit (ubersmall) so that the actual drive bay cover will be the front CD cover, but its not like a traditional stealth, because IMHO a bay of nothing doesn't match well with a bay of switches, LCDs, etc.
su root
Senior Member, --, I teach people how to read your
Ontario, Canada
[THREADJACK]You should really move that box away from that speaker.. Even if it is shielded and even at that distance, it isn't a good thing for the harddrives.. :)[/THREADJACK]
