Lian Li fan question
dfonda
Senior Golfer
N of splat W of Torin
I want to get nice fans for a Hyte Y70 case that has none. If I get a 3 pack of Lian Li for the bottom to pull air in. Should they be the reverse model ? I want them blowing on the GPU. Not sure about the back yet.
The top will have an AIO sending air out.
You want reverse blade fans if you can see them in the closed case. If they are blocked from view it doesn't matter.
