- Aug 16, 2009
Ok …. The goal here is to max out my loop but keep in all in a case that doesn't need a forklift to move. I have been contemplating doing a scratch build and although I know I can bend and weld all the components I need while using some parts from old cases I have here to make things easier I just wasn't sure I could make something that I would find visually pleasing at the same time. I have seen a few builds with the Lian-Li PC 011 Dynamic and it peaked my curiosity but left me wondering if I can fit everything I want into it, I think so and we are about to see as UPS was here yesterday with a box for me though I think that I am finally pushing up on the limits of my wife's current acceptance of my hobby as I have spent a bit more recently (since RYZEN 3000 release) then even I have thought I would. I'm not big on bling though I might add some later, we'll see how that goes and this build will be mostly a case swap as I have been in the Corsair AIR 540 for about 6 years now and it has done me well I have just ran out of room for what I want in my case.
To start …. My first impression the Lian-Li PC011 Dynamic is smaller then I expected and is actually smaller then the AIR 540 is.
The tear down begins I have allot of stuff to figure out where to put. There are 2 things I am not sure bout …… will my GF Card and waterblock fit, if my measurements are right just and fitting all my hard drives that I need fit. Maybe not but I can move them out eternally if I have too and you will probably see and additional NVMe drive added / drives added later for working drives.
