- Jun 18, 2001
- Winston Salem NC
you would thing something with the cisco name on it would be a bit better than tin cans :|
squirrel said:Lets get some specifics:
What model # router?
What model cable modem?
DHCP assigned by router or modem?
When the router needs to be recycled have all computers lost connection?
(ie do the basement comps still connect to each other via the switch? Do the upstairs comps still connect to each other?)
When the router goes out to lunch (OTL) can you access the setup page? (192.168.1.1)
It could be bad router, bad cabling or bad nic crashing the router.
Can you borrow a friends router (or purchase/return one) and see if the problem persists?
You could run an ethernet cable from the switch in the basement to the router and eliminate the network sharing comp and wireless conn as an issue. If the problem stops then look closer at those.
Cheap router here: http://www.compusa.com/products/product_info.asp?product_code=302193&pfp=BROWSE
get the updated firmware here
Cheap G wireless router here (no rebates):
http://www.fatwallet.com/forums/mes...readid=333706&highlight_key=y&keyword1=router
My Sears still had em yesterday, but for $29.
I have a similar setup - Moto 4100 Surfboard modem -> Linky BEFW 5 (?)port router/wap -> 3 wireless laptops, 1 wired comp and a linky 8 port switch. 10/100baset linky switch -> 6 computers and an old (1995- 10base-2 thinnet/10base-t baby!) 3com 8 port hub ->4 computers. My biggest problem is kids tripping over the cabling!
Posidon42 said:is there a chance this could be something to do with EMIII or FAH? These are the only programs I have running on these computers except my main machine and my wifes laptop.
Posidon42 said:.... I don't have a cable long enough (and I don't want to) to run a cable from the router on the second floor to the wireless stuff in the basement. If I did, I wouldn't be messing with all this wireless nonesense as it is. Anyone else have any ideas?
