Linux and digital cameras(USB)
DaWiper
Image Compare Man
Norway
Mandrake10:
I got this camera(olympus C310). Everything works great, but when I'm done moving the pictures from the camera to the HD and want to shutdown the camera the problems begins:
"umount /mnt/camera/" should work. Right?
Well, it doesn't. "blablabla device busy". How do I remove the device?
DaWiper said:
Mandrake10:
Do you have the /mnt/camera/ folder open or if you are using a command windows is this your current directory? If either of these is true then you can't umount it.
