linux dixtro
Mr Snub
whick version of linux is more user friendly
mandrake 8.1
or
redhat 7.2
im a newb so looking for a good way into linux
David
Forums Super Moderator
Mandrake is deemed to be the most user-friendly distro, but you should be fine with redhat. I suggest you try them both if possible - see which one you feel most comfortable with.
Mr Snub
Mr Snub
i cant try out both
so just tell me a little bit about each 1 that can make my decision from
David
OC-Rubix-Cube said:
i cant try out both
Try www.linux-mandrake.com for info on Mandrake and www.redhat.com for Redhat.
Mandrake is based on Redhat - but after the 7.x series has become a distribution in its own right.
I would choose any of them - they are all pretty similar. Try Mandrake - from what I have heard it is THE distro for newer users.
mcrites
Herndon, VA
I haven't personally run mandrake, but redhat was OK. I still never got over using rpms, I usually just installed the source packages anyways. When you feel good enough, come over to debian, with apt-get and you will be hooked for life. :D I would recommend you getting familiar with redhat or mandrake, I think it probably doesn't matter much in the long run, they both can run the same apps, the only difference is probably in the installl, and I can believe that they both are pretty easy to install now of days.
funnyperson1
Senior Member
the ease of installation for mandrake is right up there with Windows....though it didnt boot right on mine...had to make a floppy:eh?:
