su root said:
It would help if you could post the output of the "ifconfig" command.
This is the Output
[email protected] root]# ifconfig
eth0 Link encap:Ethernet HWaddr 00:E0:81:21:70:58
inet addr:192.168.1.4 Bcast:192.168.1.255 Mask:255.255.255.0
UP BROADCAST NOTRAILERS RUNNING MULTICAST MTU:1500 Metric:1
RX packets:1327 errors:0 dropped:0 overruns:0 frame:0
TX packets:917 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:100
RX bytes:970461 (947.7 Kb) TX bytes:341448 (333.4 Kb)
Interrupt:10 Base address:0xe000
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:10 errors:0 dropped:0 overruns:0 frame:0
TX packets:10 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:700 (700.0 b) TX bytes:700 (700.0 b)
Oh ya and you sayed we can try to set a Static Ip if all else fails but im on a Dynamic Host so thats not gona work, plus i was wonderign you sayed to set it to 50years ( more or less ) but if my ip updates im gona need to reset my router no?
