OC-Rubix-Cube said:what exactly is linux
what is the best type
can u run games and other apps that i would run normally under it
sorry im a newb
sorry im a newb
I believe some Windows applications can be modified to work under Linux
PenguinFreak said:There are really only two obstacles in Linux's way:
1) Mainstream developers and programs need to support linux
2) Hardware manufacturers need to support linux more often and better.
Wa11y said:
Actually, I think the two problems are supports (both hardware and software) and user friendly-ness. If there were better hardware and software support, it would start to become more user friendly, which would help it into the mainstream.
OC-Rubix-Cube said:thanx for the help
after hearing about this i might set up a dual boot config
if i could only figure out how![]()
OC-Rubix-Cube said:well im am going to be building a new comp on the 17th
so it's all open for now
