- Aug 25, 2013
So I recently liquid cooled my 590, everything was running smoothly, coolant is going through it fine, however, I open up Google Chrome and check my temps with EVGA Percision X and BAM, my temperatures almost exponentially go up to 100 Degrees Celcius and that's when I turned off my computer to protect if from frying. What could I have possibly done wrong? This is my first time liquid cooling, so I'd suppose it's not perfect and I can't really pick out what I've done wrong...
1st picture is the only one where the system is on, the rest are after it hit the temps.
Right to Left
1st Picture: The inside while it was running
2nd Picture: Showing that the reservoir is full
3rd Picture: Showing that the fan has space to blow air, the pump/reservoir/radiator is on the 1st and 2nd drive, leaving the 3rd one free, also that is a Thermaltake 760 Pro
4th Picture: The 3-pin connector is in the sys fan(recommended by a member on the forum) connector since the cpu fan is taken by the Alienware processor cooling
Also the waterblock is fairly tarnished if that helps.
Right to Left
