- May 22, 2011
- USA
After close evaluation, fittings were ok, pump was DOA, thanks Thermaltake, I'll be sure to recommend you to my ex![]()
Also I've decided to move cases, mostly because I'm planning on getting ~120.5 for my GPU and CPU and I'll most likely get either an 800D or a 900D(depending if I plan on overkill upgrading later on in life). I'm most likely gonna go through with a XPSC watercooling kit(for value) and buy separate radiators later, what I ask of you guys. Would you recommend the 800D/900D or something else? Should I get the raystorm kit as 360 or 480? I plan on doing either 1 or 2 loops, 1 loop would be 480 for gpu and cpu or I'd do 2 loops, one for gpu(120.3) and one for cpu(120.2). What are your guys' thoughts? Good or bad choice?
Welcome back.
Its all up to you how much you want to spend and what your plan might look in the future. You'll want to do this as one loop. No point in doing 2 separate loops.
With that said, you can either do a 360 for the CPU + GPU in a 800D and if you decide to add more to the loop you will need to modify the 800D or go with the 900D and add a 360 or 480 up to you for the time being on the CPU + GPU and always add to the loop as there's lots of room to play with. 800D will save you lots but is limited to space or you'll spend more with the 900D but make life way easier. I'd would go the 900D route (already have lol) as it will allow you to add whatever you want and have the ability to move heaven and earth if you choose too down the road.
