I have to say, all the chemistry involved in liquid cooling and my love for chemistry in general, makes me want to have the guts to take AP Chem next year, hard class, but REALLY interesting concepts to be learned. Also I'm starting to have a clear indication on my parts:
CPU Block: XSPC Raystorm Acetal, cheap and high quality. I hear the copper one, more expensive, is just a little behind the acetal.
GPU Block: What I'll also do, clean that sucker, because when I had the ol' TT760, I foolishly touched the copper with my fingers and it just looks hideous, and plus I COULD'VE misplaced it on the GPU, which could've also been a culprit for my temps, not too sure of my fittings being the issue. It most likely was the crap thing was designed for a single CPU, with it's 120.1 and crap pump. Who knows?
Radiator: 480mm Alphacool UT60 or Monsta since I'll be saving about $100 on res.
Reservoir: Bitspower Water Tank Z-Multi 400 Inline Reservoir Ice Red, I
need something colorful, looking at a clear reservoir isn't on my to-do list.
OR Monsoon Dual Bay D5 Res if I get over my love for cylinder reservoirs.
Pump: D5/655
Tubing: Primochill, color to be decided later, and I'll buy 2 foot, since that is ~ how much I need, I'll measure later on though, instead of 10, because I really don't need 10 and it saves $$$
Liquid: Distilled + PTNuke
Fans: Gentle Typhoon 120mm x4
LIGHTING!: Phobya Multicolor LED Strip 60cm x 3
- Phobya RBG Controller
NOTE: I'll throw in prices later once I find good deals on each, some websites are cheaper than others, especially FrozenCPU and some of my items, Alphacool Rads and XSPC Raystorm, are currently out of stock and they are cheap compared to others so I'll be on a lookout for restocking.
