Hi all,
I have recently purchased parts to build a liquid cooling set up. I received them all the other night and began the assembly last night.
I started by assembling everything on my bed and "jumped" the 24-pin mobo connector with a paper clip. It worked like a charm for about a half hour, no leaks, and then I decided it was good enough to put into my system.
Well after getting everything into my system and hooked up (hoses, fittings, clamps) I tried to jumper it again only this time the PC just powered on and the pump did not.
The res is full of liquid, no kinks, and the flow direction is correct. The pump is the MCP655-B and I have the top barb going to my radiator and the side barb going to my reservoir.
Hopefully this is an issue someone has encountered before and will be able to help me. Thanks guys!
