Little help with my Chaintech please
e_w
Hi can someone please give me some information on over clocking my machine since my bios doesn't let me do very much. I have a chaintech 6BTM mobo with a p2 450. If I adjust the bus speed in my bios above 103 my system hangs on startup. Any help would be great
Cheers
e_w
I think your in the same position I'm in. Because the P2 450 is locked, you cant move the multiplyer, and if it jammes at 103FSB then you cant go any higher, you may want to try better cooling, thats all i can suggest. I think its your processor, not your motherboard, although i dont know how far your motherboard is rated. Try your manufacturors website.
got_yogurt (Mar 01, 2001 07:18 p.m.):
My system runs OK @ 103fsb and my proc temp is less than 35c.I am wonderring though if there is any way to reduce the bus speed for the memory and AGP? Also my system will boot up @112fsb but it gets reeeeal slow.
