ok here what i ran into. i have a X6800 CPU and here the ram i use.
http://www.newegg.com/Product/Product.asp?Item=N82E16820145590
i been working on my OC over SO long now and can't seem to get past 3.6 i have done 3.6 stable for about 23 hours and it was still going fine now i ran it again at 3.7 and the most i can go is 5 hours and it stops. Now i have try 3.7 at 1.325 vore and 1.40 than 1.45 and than 1.47 still no luck. Now i set my Vdimm my FSB and MCH to .01 work for about 2 mins and stopped went to .02 with all and got it to run for the 5 hours and stopped now i don't know to much at all about timings and stuff. (And yes i have try a Mult. of 11 and 10 and 9 can't get past 3.6 i'm using water cooling so heat not a issue. But is there a way to change my timing to make it easier to get it higher i manual set the timing to stock which is 5-5-5-12 (i think) But there is where i need the help. Is there a way with the ram i use to change the timing so i can get a better OC. i know much about the timing at all. But i have figure that it must be my RAM that's stopping me here figure that i went back to a 1.325 vcore and left everything at .02 and still runnning 3.6 fine for about 12 hours. If anyone could give me some advice that would e GREAT. Thanks again
Csst
Csst
