little problem with cod4
YOO
Central Nebraska US
i just go this message: awaiting key code authorization. what is this? this is the first time ever i had a problem with this game since i bought it. it wont let me connect to the same server i have been playing for years. i updated punkbuster but that did nothing. any ideas on how to solve this issue?
jaymz9350
I get that every once in a while, sometimes it goes ahead and connects and sometimes I have to try a few times but I still eventually get connected to the server.
YOO
YOO
Central Nebraska US
how long will this last? i have been trying for over an hour and still nothing :bang head
jaymz9350
I'm not really sure, never had it not connect on a server I wanted to play on. I've gotten it when just searching around for different servers and usually just jump to the next after a few failed tries.
YOO
YOO
Central Nebraska US
wow i just tried a dozen servers and could not connect to neither. sigh
YOO
YOO
Central Nebraska US
well i cant play this morning either. does anybody know infinity ward forums? i may try posting this there and see if i can fix this stupid problem
YOO
YOO
Central Nebraska US
ok i think i found the problem. i removed my router (linksys WRT54GS) and connected my pc directly to the cable modem. after doing that i connected to the server just fine. so i pushed the reset button on the router to reset the settings. but now, i cant connect again and havent messed with anything. i dont know where to go from here. i know the router was the problem but it has not giving problems before and now outta the blue is doing this? what can i do from here? i know the router is stopping something but what? it shouldn't since nothing is blocked since i pushed the reset button.
RoC1909
Are the following ports enabled?
* UDP 1500 (outbound)
* UDP 3005 (outbound)
* UDP 3101 (outbound)
* UDP 28960
Others have had this problem, but it's usually temporary.
Also, the forums are located at http://www.infinityward.com. On occasion, you won't be able to connect because there are too many people logged in, but keep trying and eventually you will. (Frankly, this company made a BOAT LOAD of money. You would think they could upgrade their connection.)
YOO
YOO
Central Nebraska US
* UDP 28960
how would go and find out if i have those ports blocked? they shouldnt be
YOO
YOO
Central Nebraska US
well i just spent 5 hours trying to fix this thing with no luck. the only way i can play is without hooking my router and that is not possible as i am running a small network in my house. i tried disabling the firewall in the router but that didnt work either. i give up. thanks for the people that tried to help out. oh i forgot to mention that i played left 4 dead online just for kicks and it worked fine. i even tried the port thing and didnt work for cod4.
