LLC works while PC is under a full load. You should see minimum voltage fluctuation during load testing and that's what LLC is built for.
Without LLC, it is common place to see load voltage drop, what we call v-droop. It shouldn't change idle voltage much at all.
So your input voltage at load should be stuck to where you set it. The higher the LLC, the less volt droop you should encounter while load testing.
