Need some help please guys.
Im running a qx9650, i have manged to get stable at 4ghz no problem but i am confused with the volts.
Doing some research I have looked up the Load line calibration setting on my mobo ASUS Maximus extreme X38. It seesm this refers to the vdroop of the CPU voltage.
The options are Auto/ disabled and enabled. I currently have it set to auto, i have done loads of reading up on what this should (safely) be and i keep getting conflicting info.
Some sites say that using a 45m cpu you should have auto but others say that if overclocking (which of course i am and aiming for 4.2 or even higher) then enabled should be selected.
Could anybidy shed some light on this for me. I currently have the cpu volts at 1.485v in the BIOS but of course with the auto option selected the vdroop kicks in and CPUZ read around 1.4v tops when under load
I have also read that 1.4v is the max i should aim for on the 9650.
So should i have it set to Enabled or Auto?
Thanks
Thanks
