loading eth1 and 0 at boot.
kaltag
Senior Member
Boise Idaho
Good evening to you. After getting my new slackware/winxp dual boot working (after 18 repartitions and installs :D) I'm having trouble getting my orinoco wireless card and nic to get an IP address during boot. They are recognized at boot but I have to run "dhcpcd eth1" or 0 to get get it working. This also does not work if the wireless card is not installed during boot or an ethernet cable is not plugged in. I think hotplug isn't working right. How do I get both the ethernet card and wireless to obtain an IP during boot? The distro is slackware 9.1. If you need any conf files posted please ask and I will. Thank you.
Unrelated: I've got another problem (didn't want to start a third thread and look like I was spamming) I got my nvidia driver loaded and the 3d acceleration works fine but when I log out of X I don't get my command prompt. The screen is blank but I can still type commands and it works. I can run reboot and poweroff and ls and whatnot. I just can't see anything ont he screen. Here's what my XF86Config file looks like if there's something wrong with it.
Section "Module"
# This loads the DBE extension module.
Load "dbe" # Double buffer extension
# This loads the miscellaneous extensions module, and disables
# initialisation of the XFree86-DGA extension within that module.
SubSection "extmod"
Option "omit xfree86-dga" # don't initialise the DGA extension
EndSubSection
# This loads the font modules
Load "type1"
Load "freetype"
Load "speedo"
# This loads the GLX module
Load "glx"
EndSection
# Files section. This allows default font and rgb paths to be set
Section "Files"
# The location of the RGB database. Note, this is the name of the
# file minus the extension (like ".txt" or ".db"). There is normally
# no need to change the default.
RgbPath "/usr/X11R6/lib/X11/rgb"
# Multiple FontPath entries are allowed (which are concatenated together),
# as well as specifying multiple comma-separated entries in one FontPath
# command (or a combination of both methods)
# If you don't have a floating point coprocessor and emacs, Mosaic or other
# programs take long to start up, try moving the Type1 and Speedo directory
# to the end of this list (or comment them out).
FontPath "/usr/X11R6/lib/X11/fonts/local/"
FontPath "/usr/X11R6/lib/X11/fonts/misc/"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/Type1/"
FontPath "/usr/X11R6/lib/X11/fonts/CID/"
FontPath "/usr/X11R6/lib/X11/fonts/Speedo/"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi/"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi/"
FontPath "/usr/X11R6/lib/X11/fonts/cyrillic/"
# ModulePath can be used to set a search path for the X server modules.
# The default path is shown here.
# ModulePath "/usr/X11R6/lib/modules"
EndSection
# Server flags section.
Section "ServerFlags"
# Uncomment this to cause a core dump at the spot where a signal is
# received. This may leave the console in an unusable state, but may
# provide a better stack trace in the core dump to aid in debugging
# Option "NoTrapSignals"
# Uncomment this to disable the <Crtl><Alt><Fn> VT switch sequence
# (where n is 1 through 12). This allows clients to receive these key
# events.
# Option "DontVTSwitch"
# Uncomment this to disable the <Crtl><Alt><BS> server abort sequence
# This allows clients to receive this key event.
# Option "DontZap"
# Uncomment this to disable the <Crtl><Alt><KP_+>/<KP_-> mode switching
# sequences. This allows clients to receive these key events.
# Option "DontZoom"
# Uncomment this to disable tuning with the xvidtune client. With
# it the client can still run and fetch card and monitor attributes,
# but it will not be allowed to change them. If it tries it will
# receive a protocol error.
# Option "DisableVidModeExtension"
# Uncomment this to enable the use of a non-local xvidtune client.
# Option "AllowNonLocalXvidtune"
# Uncomment this to disable dynamically modifying the input device
# (mouse and keyboard) settings.
# Option "DisableModInDev"
# Uncomment this to enable the use of a non-local client to
# change the keyboard or mouse settings (currently only xset).
# Option "AllowNonLocalModInDev"
# Set the basic blanking screen saver timeout.
# Option "blank time" "10" # 10 minutes
# Set the DPMS timeouts. These are set here because they are global
# rather than screen-specific. These settings alone don't enable DPMS.
# It is enabled per-screen (or per-monitor), and even then only when
# the driver supports it.
# Option "standby time" "20"
# Option "suspend time" "30"
# Option "off time" "60"
# On some platform the server needs to estimate the sizes of PCI
# memory and pio ranges. This is done by assuming that PCI ranges
# don't overlap. Some broken BIOSes tend to set ranges of inactive
# devices wrong. Here one can adjust how aggressive the assumptions
# should be. Default is 0.
# Option "EstimateSizesAggresively" "0"
EndSection
# Input devices
# Core keyboard's InputDevice section
Section "InputDevice"
Identifier "Keyboard1"
Driver "Keyboard"
# For most OSs the protocol can be omitted (it defaults to "Standard").
# When using XQUEUE (only for SVR3 and SVR4, but not Solaris),
# uncomment the following line.
# Option "Protocol" "Xqueue"
# Set the keyboard auto repeat parameters. Not all platforms implement
# this.
# Option "AutoRepeat" "500 5"
# Specifiy which keyboard LEDs can be user-controlled (eg, with xset(1)).
# Option "Xleds" "1 2 3"
# To disable the XKEYBOARD extension, uncomment XkbDisable.
# Option "XkbDisable"
# To customise the XKB settings to suit your keyboard, modify the
# lines below (which are the defaults). For example, for a European
# keyboard, you will probably want to use one of:
# Option "XkbModel" "pc102"
# Option "XkbModel" "pc105"
# If you have a Microsoft Natural keyboard, you can use:
# Option "XkbModel" "microsoft"
# If you have a US "windows" keyboard you will want:
# Option "XkbModel" "pc104"
# Then to change the language, change the Layout setting.
# For example, a german layout can be obtained with:
# Option "XkbLayout" "de"
# or:
# Option "XkbVariant" "nodeadkeys"
# If you'd like to switch the positions of your capslock and
# control keys, use:
# Option "XkbOptions" "ctrl:swapcaps"
# These are the default XKB settings for XFree86
# Option "XkbRules" "xfree86"
# Option "XkbModel" "pc101"
# Option "XkbLayout" "us"
# Option "XkbVariant" ""
# Option "XkbOptions" ""
EndSection
# Core Pointer's InputDevice section
# Identifier and driver
Identifier "Mouse1"
Driver "mouse"
# On platforms where PnP mouse detection is supported the following
# protocol setting can be used when using a newer PnP mouse:
# Option "Protocol" "Auto"
# The available mouse protocols types that you can set below are:
# Auto BusMouse GlidePoint GlidePointPS/2 IntelliMouse IMPS/2
# Logitech Microsoft MMHitTab MMSeries Mouseman MouseManPlusPS/2
# MouseSystems NetMousePS/2 NetScrollPS/2 OSMouse PS/2 SysMouse
# ThinkingMouse ThinkingMousePS/2 Xqueue
Option "Protocol" "PS/2"
# The mouse device. The device is normally set to /dev/mouse,
# which is usually a symbolic link to the real device.
Option "Device" "/dev/mouse"
# Option "Device" "/dev/psaux"
# Option "Device" "/dev/ttyS0"
# Option "Device" "/dev/ttyS1"
# When using XQUEUE, comment out the above two lines, and uncomment
# the following line.
# Baudrate and SampleRate are only for some Logitech mice. In
# almost every case these lines should be omitted.
# Option "BaudRate" "9600"
# Option "SampleRate" "150"
# Emulate3Buttons is an option for 2-button Microsoft mice
# Emulate3Timeout is the timeout in milliseconds (default is 50ms)
# Option "Emulate3Buttons"
# Option "Emulate3Timeout" "50"
# ChordMiddle is an option for some 3-button Logitech mice
# Option "ChordMiddle"
EndSection
# Some examples of extended input devices
# Section "InputDevice"
# Identifier "spaceball"
# Driver "magellan"
# Option "Device" "/dev/cua0"
# EndSection
# Identifier "spaceball2"
# Driver "spaceorb"
# EndSection
# Identifier "touchscreen0"
# Driver "microtouch"
# Option "MinX" "1412"
# Option "MaxX" "15184"
# Option "MinY" "15372"
# Option "MaxY" "1230"
# Option "ScreenNumber" "0"
# Option "ReportingMode" "Scaled"
# Option "ButtonNumber" "1"
# Option "SendCoreEvents"
# EndSection
# Identifier "touchscreen1"
# Driver "elo2300"
# Option "MinX" "231"
# Option "MaxX" "3868"
# Option "MinY" "3858"
# Option "MaxY" "272"
# Option "ButtonThreshold" "17"
# EndSection
# Monitor section
# Any number of monitor sections may be present
Section "Monitor"
Identifier "My Monitor"
# HorizSync is in kHz unless units are specified.
# HorizSync may be a comma separated list of discrete values, or a
# comma separated list of ranges of values.
# NOTE: THE VALUES HERE ARE EXAMPLES ONLY. REFER TO YOUR MONITOR'S
# USER MANUAL FOR THE CORRECT NUMBERS.
HorizSync 31.5 - 50.0
# HorizSync 30-64 # multisync
# HorizSync 31.5, 35.2 # multiple fixed sync frequencies
# HorizSync 15-25, 30-50 # multiple ranges of sync frequencies
# VertRefresh is in Hz unless units are specified.
# VertRefresh may be a comma separated list of discrete values, or a
VertRefresh 40-90
EndSection
# Graphics device section
# Any number of graphics device sections may be present
Section "Device"
Identifier "VESA Framebuffer"
Driver "nvidia"
#VideoRam 32768
# Insert Clocks lines here if appropriate
EndSection
# Screen sections
# Any number of screen sections may be present. Each describes
# the configuration of a single screen. A single specific screen section
# may be specified from the X server command line with the "-screen"
# option.
Section "Screen"
Identifier "Screen 1"
Device "VESA Framebuffer"
Monitor "My Monitor"
# If your card can handle it, a higher default color depth (like 24 or 32)
# is highly recommended.
# DefaultDepth 8
# DefaultDepth 16
DefaultDepth 24
# DefaultDepth 32
# "1024x768" is also a conservative usable default resolution. If you
# have a better monitor, feel free to try resolutions such as
# "1152x864", "1280x1024", "1600x1200", and "1800x1400" (or whatever your
# card/monitor can produce)
Subsection "Display"
Depth 8
Modes "1024x768" "800x600" "640x480"
EndSubsection
Depth 16
EndSubsection
Depth 24
EndSubsection
Depth 32
EndSubsection
EndSection
# ServerLayout sections.
# Any number of ServerLayout sections may be present. Each describes
# the way multiple screens are organised. A specific ServerLayout
# section may be specified from the X server command line with the
# "-layout" option. In the absence of this, the first section is used.
# When now ServerLayout section is present, the first Screen section
# is used alone.
Section "ServerLayout"
# The Identifier line must be present
Identifier "Simple Layout"
# Each Screen line specifies a Screen section name, and optionally
# the relative position of other screens. The four names after
# primary screen name are the screens to the top, bottom, left and right
# of the primary screen. In this example, screen 2 is located to the
# right of screen 1.
Screen "Screen 1"
# Each InputDevice line specifies an InputDevice section name and
# optionally some options to specify the way the device is to be
# used. Those options include "CorePointer", "CoreKeyboard" and
# "SendCoreEvents".
InputDevice "Mouse1" "CorePointer"
InputDevice "Keyboard1" "CoreKeyboard"
EndSection
the rc scripts prolly diff. but try
rc-update add net.eth0 default
rc-update add net.eth1 default
(this is after configuring that net file, i think its /etc/conf.d/net)
works for gentoo, dunno about slack, sorry
When the install program ran the network setup, how did you setup the machine, DHCP or static?
Off the top of my head, the rc file to initalize the network devices is /etc/rc.d/rc.inet1, so you'll need to look at that file. Editing the script and figuring out what you need to do should be pretty self explanitory, since there are lots of comments left in the file, at least it was like that in 8.0/8.1. I'll have to boot up into Slack, to tell you exactly what you'll want to do, so I'll have that in another post.
I set the network to use DHCP during the install. I'll look into the rc.inet1 file and see if I can't get something working.
Re: Re: loading eth1 and 0 at boot.
I'm pretty sure rc-update is a gentoo-specific tool. etc-update is also.
kaltag: Can you elaborate on the X issue? Does anything appear on the screen? What if you switch to a different virtual terminal (ctrl +alt + f[1 - 6])? How are you starting X?
For the X issue: durring the boot I get a normal prompt and everything in the command line works fine (I can see it) login works fine and I can do all I want until I load X then if I exit I get nothing back on the screen but the commands still work. I startx using "startx" after logging on as either root or a user.
For the X issue. What happens when you type reset at the prompt after shutting down X?
For the wireless nic issue. I looked through the script, and it was a bit different than the script in 8.0/8.1. Still, it should automatically detect, detect, load the drivers, and get and IP address for both cards, at least that's they way the script makes it appear. The easiest solution would be to add a line at the end of rc.M (or possibly rc.local0 along the lines of
/usr/sbin/dhcpcd eth0
/usr/sbindhcpdcd eth1
that does the samething as you would, but now it will run automatically after you login.
Do you have hotplug support in your kernel? If not, you might want to recompile a new kernel with that support in it.
I got the wireless working right now :D. I still don't have a prompt after quitting X though. I typed reset but it didn't do anything. Is it possible that the nvidia driver is having some sort of issue with the framebuffer command line that lilo runs? How do I get lilo to load linuz with the standard (non-framebuffer) command line?
Yeah that framebuffer might be an issue.
Add this line vga = normal and rem out all other vga options to get the standard console.
