VP6
Single piii 700e OC 933 1.70v
Before I start committing wads of cash to this case-cooling project. I decided to do a few test runs by cooling the whole case and checking on the performance.
Living in Canada in the middle of the winter makes this very easy. Its –21 outside today so I just opened the door.
Before I started temps were.
Room 27c
CPU1 39c running seti full time
Chipset temp 23c
I then dropped the room temp down to 10c
Cpu1 dropped to 15c
And the chip set dropped to 18c
I started getting lock ups at these temps. I remember seeing on Intel’s web site that the rated temps for this chip were 18c to 80c <unfortunately Intel’s site is down today so I can’t double check these numbers>
I always thought that colder was better…
What could be causing these lock ups?
Is the chip not happy or is it something else on the board that doesn’t like the cold temps?
Should I be backing off my voltage at these cooler temps?
Room 27c
Chipset temp 23c
Cpu1 dropped to 15c
