Lock ups
Wicked Klown
Hard *** Southern Boy Senior
Sheboygan, Wisconsin
The last couple of days I've been getting lock ups while playing AA. Only thing that is overclocked is my cpu. If I don't play the game my computer ruuns all day with no problems. I thought maybe the fan on the video card died but it's still working. I havn't changed anything since I built the computer. I'm running at 133FSB so my PCI/AGP are in specs. What could be wrong?
PS forgot system specs. CPU 800 celeron @ 1064, PC133 ram 512mb, AOpen AX34 Pro II, 300 watt PSU.
cullam3n
San Antonio, TX
Some things to try:
1. Lower down the OC on the video card.
- Or maybe it isn't receiving enough cooling, too hot in the case?
2. Raise the voltage on the CPU; it might be freezing up.
3. Get a higher rated PSU.
Those are the only things I can think of off the top of my head.
-PC
Wicked Klown
Wicked Klown
Cullam3n said:
Some things to try:
Video card is not overclocked
voltage is 1.85 and ruuing at a nice cool 21C idle and 24Cload
cullam3n
San Antonio, TX
Okay. How is the case temp? Is the fan on the video card working? Can you check the volt lines on your PSU? You can do it in your bios or look for MBM5 (Motherboard Monitor 5).
-PC
Wicked Klown
Wicked Klown
Case temp is about 23C cause the top and sides are off. Yes the fan for the video card HS is working first thing I checked. I'll get back to you on the voltages of the PSU.
PS ok the voltages are +2.5 is 2.59, +3.3 is 3.25, +5 is 5.12 and the +12 is 12.60 and the Vcore is set at 1.77
ziah
northeast usa
same game!! mine does the same thing. no overclocking though. temperatures are at 44-45c. the second the cpu hits 47c it freezes the system. and i have a 90mm fan on the vid card. as soon as it locks i check the sinks but the geforce sink is cold and the cpu is not very hot either.
~z
Wicked Klown
Wicked Klown
Not really sure bout mine. I got it from a local computer shop. Funny thing is, is that it's the same one I've always used for in this system.
