- May 17, 2005
- High Desert, Calif.
On a sandy bridge rig running Debian(Squeeze) I've been getting odd 'lockups' when the kernel tries to boot-screen shot
I've tried to glean some understanding of the problem by looking at dmesg; does anyone see something I can investigate?
Edit: solution found, see this post.
Code:
[ 0.974262] system 00:0c: iomem range 0xfec00000-0xfec00fff could not be reserved
[ 0.974264] system 00:0c: iomem range 0xfed10000-0xfed1dfff has been reserved
[ 0.974265] system 00:0c: iomem range 0xfed20000-0xfed8ffff has been reserved
[ 0.974267] system 00:0c: iomem range 0xfee00000-0xfee00fff has been reserved
[ 0.974268] system 00:0c: iomem range 0xffb00000-0xffb7ffff has been reserved
[ 0.974270] system 00:0c: iomem range 0xfff00000-0xffffffff has been reserved
[ 0.974271] system 00:0c: iomem range 0xe0000-0xeffff has been reserved
[ 0.974273] system 00:0c: iomem range 0x20000000-0x201fffff could not be reserved
[ 0.974274] system 00:0c: iomem range 0x40000000-0x400fffff could not be reserved
[ 0.974276] system 00:0c: iomem range 0xdf800000-0xdfffffff could not be reserved
[ 0.978921] pci 0000:00:01.0: PCI bridge, secondary bus 0000:01
[ 0.978922] pci 0000:00:01.0: IO window: 0xd000-0xdfff
[ 0.978924] pci 0000:00:01.0: MEM window: 0xf6000000-0xf9ffffff
[ 0.978926] pci 0000:00:01.0: PREFETCH window: 0x000000e0000000-0x000000efffffff
[ 0.978929] pci 0000:00:01.1: PCI bridge, secondary bus 0000:02
[ 0.978930] pci 0000:00:01.1: IO window: disabled
[ 0.978931] pci 0000:00:01.1: MEM window: 0xfbe00000-0xfbefffff
[ 0.978933] pci 0000:00:01.1: PREFETCH window: disabled
[ 0.978935] pci 0000:00:1c.0: PCI bridge, secondary bus 0000:03
[ 0.978937] pci 0000:00:1c.0: IO window: 0x2000-0x2fff
[ 0.978941] pci 0000:00:1c.0: MEM window: 0xf4000000-0xf41fffff
[ 0.978944] pci 0000:00:1c.0: PREFETCH window: 0x000000f4200000-0x000000f43fffff
[ 0.978949] pci 0000:00:1c.2: PCI bridge, secondary bus 0000:04
[ 0.978951] pci 0000:00:1c.2: IO window: 0xe000-0xefff
[ 0.978954] pci 0000:00:1c.2: MEM window: disabled
[ 0.978957] pci 0000:00:1c.2: PREFETCH window: 0x000000fbd00000-0x000000fbdfffff
[ 0.978962] pci 0000:05:00.0: PCI bridge, secondary bus 0000:06
[ 0.978963] pci 0000:05:00.0: IO window: disabled
[ 0.978971] pci 0000:05:00.0: MEM window: disabled
[ 0.978976] pci 0000:05:00.0: PREFETCH window: disabled
[ 0.978987] pci 0000:00:1c.3: PCI bridge, secondary bus 0000:05
[ 0.978988] pci 0000:00:1c.3: IO window: disabled
[ 0.978991] pci 0000:00:1c.3: MEM window: disabled
[ 0.978994] pci 0000:00:1c.3: PREFETCH window: disabled
[ 0.978999] pci 0000:00:1e.0: PCI bridge, secondary bus 0000:07
[ 0.979000] pci 0000:00:1e.0: IO window: disabled
[ 0.979003] pci 0000:00:1e.0: MEM window: disabled
[ 0.979005] pci 0000:00:1e.0: PREFETCH window: disabled
[ 0.979013] alloc irq_desc for 16 on node -1
[ 0.979014] alloc kstat_irqs on node -1
[ 0.979017] pci 0000:00:01.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 0.979019] pci 0000:00:01.0: setting latency timer to 64
[ 0.979022] pci 0000:00:01.1: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 0.979023] pci 0000:00:01.1: setting latency timer to 64
[ 0.979029] pci 0000:00:1c.0: enabling device (0000 -> 0003)
[ 0.979031] pci 0000:00:1c.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 0.979035] pci 0000:00:1c.0: setting latency timer to 64
[ 0.979041] alloc irq_desc for 18 on node -1
[ 0.979042] alloc kstat_irqs on node -1
[ 0.979043] pci 0000:00:1c.2: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[ 0.979046] pci 0000:00:1c.2: setting latency timer to 64
[ 0.979053] alloc irq_desc for 19 on node -1
[ 0.979053] alloc kstat_irqs on node -1
[ 0.979057] pci 0000:00:1c.3: PCI INT D -> GSI 19 (level, low) -> IRQ 19
[ 0.979060] pci 0000:00:1c.3: setting latency timer to 64
[ 0.979072] pci 0000:05:00.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
[ 0.979081] pci 0000:05:00.0: setting latency timer to 64
[ 0.979087] pci 0000:00:1e.0: setting latency timer to 64
[ 0.979090] pci_bus 0000:00: resource 0 io: [0x00-0xffff]
[ 0.979091] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffffffffffff]
[ 0.979092] pci_bus 0000:01: resource 0 io: [0xd000-0xdfff]
[ 0.979094] pci_bus 0000:01: resource 1 mem: [0xf6000000-0xf9ffffff]
[ 0.979095] pci_bus 0000:01: resource 2 pref mem [0xe0000000-0xefffffff]
[ 0.979096] pci_bus 0000:02: resource 1 mem: [0xfbe00000-0xfbefffff]
[ 0.979097] pci_bus 0000:03: resource 0 io: [0x2000-0x2fff]
[ 0.979099] pci_bus 0000:03: resource 1 mem: [0xf4000000-0xf41fffff]
[ 0.979100] pci_bus 0000:03: resource 2 pref mem [0xf4200000-0xf43fffff]
[ 0.979101] pci_bus 0000:04: resource 0 io: [0xe000-0xefff]
[ 0.979102] pci_bus 0000:04: resource 2 pref mem [0xfbd00000-0xfbdfffff]
[ 0.979104] pci_bus 0000:07: resource 3 io: [0x00-0xffff]
[ 0.979105] pci_bus 0000:07: resource 4 mem: [0x000000-0xffffffffffffffff]
[ 0.979118] NET: Registered protocol family 2
[ 0.979201] IP route cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.979696] TCP established hash table entries: 524288 (order: 11, 8388608 bytes)
[ 0.980557] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.980671] TCP: Hash tables configured (established 524288 bind 65536)
[ 0.980672] TCP reno registered
[ 0.980730] NET: Registered protocol family 1
[ 0.980751] pci 0000:00:1a.0: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[ 0.997531] pci 0000:00:1a.0: PCI INT C disabled
[ 0.997542] alloc irq_desc for 23 on node -1
[ 0.997543] alloc kstat_irqs on node -1
[ 0.997547] pci 0000:00:1d.0: PCI INT A -> GSI 23 (level, low) -> IRQ 23
[ 1.013483] pci 0000:00:1d.0: PCI INT A disabled
[ 1.013493] pci 0000:01:00.0: Boot video device
[ 1.013500] alloc irq_desc for 17 on node -1
[ 1.013501] alloc kstat_irqs on node -1
[ 1.013503] pci 0000:02:00.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 1.013517] pci 0000:02:00.0: PCI INT A disabled
[ 1.013543] Unpacking initramfs...
[ 1.135209] Freeing initrd memory: 9112k freed
[ 1.136330] audit: initializing netlink socket (disabled)
[ 1.136337] type=2000 audit(1403042109.909:1): initialized
[ 1.138496] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 1.139236] VFS: Disk quotas dquot_6.5.2
[ 1.139263] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.139305] msgmni has been set to 7897
[ 1.139443] alg: No test for stdrng (krng)
[ 1.139468] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 1.139470] io scheduler noop registered
[ 1.139471] io scheduler anticipatory registered
[ 1.139472] io scheduler deadline registered
[ 1.139500] io scheduler cfq registered (default)
[ 1.139556] alloc irq_desc for 24 on node -1
[ 1.139557] alloc kstat_irqs on node -1
[ 1.139562] pcieport 0000:00:01.0: irq 24 for MSI/MSI-X
[ 1.139565] pcieport 0000:00:01.0: setting latency timer to 64
[ 1.139609] alloc irq_desc for 25 on node -1
[ 1.139610] alloc kstat_irqs on node -1
[ 1.139613] pcieport 0000:00:01.1: irq 25 for MSI/MSI-X
[ 1.139615] pcieport 0000:00:01.1: setting latency timer to 64
[ 1.139681] alloc irq_desc for 26 on node -1
[ 1.139682] alloc kstat_irqs on node -1
[ 1.139687] pcieport 0000:00:1c.0: irq 26 for MSI/MSI-X
[ 1.139694] pcieport 0000:00:1c.0: setting latency timer to 64
[ 1.139784] alloc irq_desc for 27 on node -1
[ 1.139785] alloc kstat_irqs on node -1
[ 1.139790] pcieport 0000:00:1c.2: irq 27 for MSI/MSI-X
[ 1.139797] pcieport 0000:00:1c.2: setting latency timer to 64
[ 1.139881] alloc irq_desc for 28 on node -1
[ 1.139881] alloc kstat_irqs on node -1
[ 1.139887] pcieport 0000:00:1c.3: irq 28 for MSI/MSI-X
[ 1.139893] pcieport 0000:00:1c.3: setting latency timer to 64
[ 1.140624] Linux agpgart interface v0.103
[ 1.140642] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.140729] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.140918] 00:07: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.141010] input: Macintosh mouse button emulation as /devices/virtual/input/input0
[ 1.141039] PNP: No PS/2 controller found. Probing ports directly.
[ 1.174249] Failed to disable AUX port, but continuing anyway... Is this a SiS?
[ 1.174250] If AUX port is really absent please use the 'i8042.noaux' option.
[ 1.407156] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.407204] mice: PS/2 mouse device common for all mice
[ 1.407226] rtc_cmos 00:04: RTC can wake from S4
[ 1.407244] rtc_cmos 00:04: rtc core: registered rtc_cmos as rtc0
[ 1.407267] rtc0: alarms up to one month, 242 bytes nvram, hpet irqs
[ 1.407272] cpuidle: using governor ladder
[ 1.407273] cpuidle: using governor menu
[ 1.407276] No iBFT detected.
[ 1.407424] TCP cubic registered
[ 1.407481] NET: Registered protocol family 10
[ 1.407825] Mobile IPv6
[ 1.407826] NET: Registered protocol family 17
[ 1.407865] PM: Resume from disk failed.
[ 1.407869] registered taskstats version 1
[ 1.408197] rtc_cmos 00:04: setting system clock to 2014-06-17 21:55:11 UTC (1403042111)
[ 1.408221] Initalizing network drop monitor service
[ 1.408237] Freeing unused kernel memory: 592k freed
[ 1.408283] Write protecting the kernel read-only data: 4236k
[ 1.415406] udev[116]: starting version 164
[ 1.432563] usbcore: registered new interface driver usbfs
[ 1.432584] usbcore: registered new interface driver hub
[ 1.432610] usbcore: registered new device driver usb
[ 1.438371] SCSI subsystem initialized
[ 1.439169] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.439189] ehci_hcd 0000:00:1a.0: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[ 1.439210] ehci_hcd 0000:00:1a.0: setting latency timer to 64
[ 1.439212] ehci_hcd 0000:00:1a.0: EHCI Host Controller
[ 1.439222] ehci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 1
[ 1.439246] ehci_hcd 0000:00:1a.0: debug port 2
[ 1.443124] ehci_hcd 0000:00:1a.0: cache line size of 32 is not supported
[ 1.443135] ehci_hcd 0000:00:1a.0: irq 18, io mem 0xfbffe000
[ 1.445891] libata version 3.00 loaded.
[ 1.448522] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 1.448539] r8169 0000:04:00.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 1.448580] r8169 0000:04:00.0: setting latency timer to 64
[ 1.448629] alloc irq_desc for 29 on node -1
[ 1.448631] alloc kstat_irqs on node -1
[ 1.448645] r8169 0000:04:00.0: irq 29 for MSI/MSI-X
[ 1.449054] r8169 0000:04:00.0: eth0: RTL8168e/8111e at 0xffffc90000674000, 1c:6f:65:d5:67:12, XID 0c200000 IRQ 29
[ 1.456447] ehci_hcd 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[ 1.456458] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.456460] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.456461] usb usb1: Product: EHCI Host Controller
[ 1.456462] usb usb1: Manufacturer: Linux 2.6.32-5-amd64 ehci_hcd
[ 1.456463] usb usb1: SerialNumber: 0000:00:1a.0
[ 1.456505] usb usb1: configuration #1 chosen from 1 choice
[ 1.456522] hub 1-0:1.0: USB hub found
[ 1.456525] hub 1-0:1.0: 2 ports detected
[ 1.456550] ata_piix 0000:00:1f.2: version 2.13
[ 1.456559] ata_piix 0000:00:1f.2: PCI INT B -> GSI 19 (level, low) -> IRQ 19
[ 1.456562] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[ 1.456584] ata_piix 0000:00:1f.2: setting latency timer to 64
[ 1.456618] scsi0 : ata_piix
[ 1.456659] scsi1 : ata_piix
[ 1.457079] ata1: SATA max UDMA/133 cmd 0xff00 ctl 0xfe00 bmdma 0xfb00 irq 19
[ 1.457083] ata2: SATA max UDMA/133 cmd 0xfd00 ctl 0xfc00 bmdma 0xfb08 irq 19
[ 1.457096] ehci_hcd 0000:00:1d.0: PCI INT A -> GSI 23 (level, low) -> IRQ 23
[ 1.457109] ehci_hcd 0000:00:1d.0: setting latency timer to 64
[ 1.457112] ehci_hcd 0000:00:1d.0: EHCI Host Controller
[ 1.457116] ehci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 1.457140] ehci_hcd 0000:00:1d.0: debug port 2
[ 1.461018] ehci_hcd 0000:00:1d.0: cache line size of 32 is not supported
[ 1.461026] ehci_hcd 0000:00:1d.0: irq 23, io mem 0xfbffd000
[ 1.476390] ehci_hcd 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[ 1.476397] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.476399] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.476400] usb usb2: Product: EHCI Host Controller
[ 1.476401] usb usb2: Manufacturer: Linux 2.6.32-5-amd64 ehci_hcd
[ 1.476402] usb usb2: SerialNumber: 0000:00:1d.0
[ 1.476432] usb usb2: configuration #1 chosen from 1 choice
[ 1.476445] hub 2-0:1.0: USB hub found
[ 1.476448] hub 2-0:1.0: 2 ports detected
[ 1.476478] ata_piix 0000:00:1f.5: PCI INT B -> GSI 19 (level, low) -> IRQ 19
[ 1.476481] ata_piix 0000:00:1f.5: MAP [ P0 -- P1 -- ]
[ 1.476500] ata_piix 0000:00:1f.5: setting latency timer to 64
[ 1.476523] scsi2 : ata_piix
[ 1.476554] scsi3 : ata_piix
[ 1.476890] ata3: SATA max UDMA/133 cmd 0xf800 ctl 0xf700 bmdma 0xf400 irq 19
[ 1.476892] ata4: SATA max UDMA/133 cmd 0xf600 ctl 0xf500 bmdma 0xf408 irq 19
[ 1.532783] xhci_hcd 0000:02:00.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 1.532796] xhci_hcd 0000:02:00.0: setting latency timer to 64
[ 1.532798] xhci_hcd 0000:02:00.0: xHCI Host Controller
[ 1.532803] xhci_hcd 0000:02:00.0: new USB bus registered, assigned bus number 3
[ 1.532901] xhci_hcd 0000:02:00.0: irq 17, io mem 0xfbefe000
[ 1.536351] usb usb3: config 1 interface 0 altsetting 0 endpoint 0x81 has no SuperSpeed companion descriptor
[ 1.536355] usb usb3: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.536356] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.536357] usb usb3: Product: xHCI Host Controller
[ 1.536358] usb usb3: Manufacturer: Linux 2.6.32-5-amd64 xhci_hcd
[ 1.536359] usb usb3: SerialNumber: 0000:02:00.0
[ 1.536393] usb usb3: configuration #1 chosen from 1 choice
[ 1.536395] xHCI xhci_add_endpoint called for root hub
[ 1.536396] xHCI xhci_check_bandwidth called for root hub
[ 1.536410] hub 3-0:1.0: USB hub found
[ 1.536413] hub 3-0:1.0: 4 ports detected
[ 1.766092] usb 1-1: new high speed USB device using ehci_hcd and address 2
[ 1.804695] ata3: SATA link down (SStatus 0 SControl 300)
[ 1.898134] usb 1-1: New USB device found, idVendor=8087, idProduct=0024
[ 1.898135] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.898167] usb 1-1: configuration #1 chosen from 1 choice
[ 1.898275] hub 1-1:1.0: USB hub found
[ 1.898382] hub 1-1:1.0: 6 ports detected
[ 1.957601] ata4: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 1.965752] ata4.00: ATAPI: Optiarc DVD RW AD-7260S, 1.03, max UDMA/100
[ 1.985704] ata4.00: configured for UDMA/100
[ 2.009424] usb 2-1: new high speed USB device using ehci_hcd and address 2
[ 2.141436] usb 2-1: New USB device found, idVendor=8087, idProduct=0024
[ 2.141437] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.141467] usb 2-1: configuration #1 chosen from 1 choice
[ 2.141583] hub 2-1:1.0: USB hub found
[ 2.141686] hub 2-1:1.0: 8 ports detected
[ 2.248834] ata2.00: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.248850] ata2.01: SATA link down (SStatus 0 SControl 300)
[ 2.248854] ata1.00: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.248867] ata1.01: SATA link down (SStatus 0 SControl 300)
[ 2.252757] usb 3-3: new high speed USB device using xhci_hcd and address 0
[ 2.262729] ata1.00: ATA-8: WDC WD2500AAJS-00L7A0, 01.03E01, max UDMA/133
[ 2.262731] ata1.00: 488397168 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 2.270501] xhci_hcd 0000:02:00.0: WARN: short transfer on control ep
[ 2.270875] xhci_hcd 0000:02:00.0: WARN: short transfer on control ep
[ 2.271248] xhci_hcd 0000:02:00.0: WARN: short transfer on control ep
[ 2.271623] xhci_hcd 0000:02:00.0: WARN: short transfer on control ep
[ 2.271754] usb 3-3: New USB device found, idVendor=03f0, idProduct=8011
[ 2.271755] usb 3-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.271756] usb 3-3: Product: Deskjet D2600 series
[ 2.271757] usb 3-3: Manufacturer: HP
[ 2.271758] usb 3-3: SerialNumber: CN01FDF42705C9
[ 2.271790] usb 3-3: configuration #1 chosen from 1 choice
[ 2.271795] usb 3-3: ep 0x8 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 2.271799] usb 3-3: ep 0x89 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 2.271802] usb 3-3: ep 0x6 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 2.271806] usb 3-3: ep 0x87 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 2.277629] ata1.00: configured for UDMA/133
[ 2.277692] scsi 0:0:0:0: Direct-Access ATA WDC WD2500AAJS-0 01.0 PQ: 0 ANSI: 5
[ 2.289980] ata2.00: HPA detected: current 488395055, native 488397168
[ 2.289982] ata2.00: ATA-8: WDC WD2500AAJS-61B4A0, 01.03A01, max UDMA/133
[ 2.289984] ata2.00: 488395055 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 2.309130] ata2.00: configured for UDMA/133
[ 2.309175] scsi 1:0:0:0: Direct-Access ATA WDC WD2500AAJS-6 01.0 PQ: 0 ANSI: 5
[ 2.310508] scsi 3:0:0:0: CD-ROM Optiarc DVD RW AD-7260S 1.03 PQ: 0 ANSI: 5
[ 2.315781] sd 0:0:0:0: [sda] 488397168 512-byte logical blocks: (250 GB/232 GiB)
[ 2.315797] sd 1:0:0:0: [sdb] 488395055 512-byte logical blocks: (250 GB/232 GiB)
[ 2.315827] sd 0:0:0:0: [sda] Write Protect is off
[ 2.315829] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.315837] sd 1:0:0:0: [sdb] Write Protect is off
[ 2.315839] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 2.315846] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.315857] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.315985] sda:
[ 2.316065] sdb:sr0: scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
[ 2.318253] Uniform CD-ROM driver Revision: 3.20
[ 2.318306] sr 3:0:0:0: Attached scsi CD-ROM sr0
[ 2.323510] sdb1
[ 2.323646] sd 1:0:0:0: [sdb] Attached SCSI disk
[ 2.325221] sda1 sda2 <
[ 2.344609] usb 1-1.1: new high speed USB device using ehci_hcd and address 3
[ 2.348559] sda5 >
[ 2.348730] sd 0:0:0:0: [sda] Attached SCSI disk
[ 2.350459] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 2.350475] sd 1:0:0:0: Attached scsi generic sg1 type 0
[ 2.350489] sr 3:0:0:0: Attached scsi generic sg2 type 5
[ 2.437714] usb 1-1.1: New USB device found, idVendor=04a9, idProduct=1909
[ 2.437716] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.437717] usb 1-1.1: Product: CanoScan
[ 2.437718] usb 1-1.1: Manufacturer: Canon
[ 2.437755] usb 1-1.1: configuration #1 chosen from 1 choice
[ 2.508138] usb 2-1.5: new low speed USB device using ehci_hcd and address 3
[ 2.604983] usb 2-1.5: New USB device found, idVendor=045e, idProduct=0040
[ 2.604985] usb 2-1.5: New USB device strings: Mfr=1, Product=3, SerialNumber=0
[ 2.604987] usb 2-1.5: Product: Microsoft 3-Button Mouse with IntelliEye(TM)
[ 2.604988] usb 2-1.5: Manufacturer: Microsoft
[ 2.605023] usb 2-1.5: configuration #1 chosen from 1 choice
[ 2.608993] usbcore: registered new interface driver hiddev
[ 2.610918] input: Microsoft Microsoft 3-Button Mouse with IntelliEye(TM) as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5/2-1.5:1.0/input/input1
[ 2.610965] generic-usb 0003:045E:0040.0001: input,hidraw0: USB HID v1.10 Mouse [Microsoft Microsoft 3-Button Mouse with IntelliEye(TM)] on usb-0000:00:1d.0-1.5/input0
[ 2.610980] usbcore: registered new interface driver usbhid
[ 2.610982] usbhid: v2.6:USB HID core driver
[ 2.648632] PM: Starting manual resume from disk
[ 2.648633] PM: Resume from partition 8:5
[ 2.648634] PM: Checking hibernation image.
[ 2.648789] PM: Error -22 checking image file
[ 2.648791] PM: Resume from disk failed.
[ 2.675660] usb 2-1.6: new full speed USB device using ehci_hcd and address 4
[ 2.706915] kjournald starting. Commit interval 5 seconds
[ 2.706918] EXT3-fs: mounted filesystem with ordered data mode.
[ 2.772379] usb 2-1.6: New USB device found, idVendor=413c, idProduct=1001
[ 2.772381] usb 2-1.6: New USB device strings: Mfr=3, Product=1, SerialNumber=0
[ 2.772382] usb 2-1.6: Product: Dell USB Keyboard Hub
[ 2.772383] usb 2-1.6: Manufacturer: NMB
[ 2.772426] usb 2-1.6: configuration #1 chosen from 1 choice
[ 2.773010] hub 2-1.6:1.0: USB hub found
[ 2.773126] hub 2-1.6:1.0: 3 ports detected
[ 3.042733] usb 2-1.6.1: new full speed USB device using ehci_hcd and address 5
[ 3.135338] usb 2-1.6.1: New USB device found, idVendor=413c, idProduct=2001
[ 3.135340] usb 2-1.6.1: New USB device strings: Mfr=3, Product=2, SerialNumber=0
[ 3.135342] usb 2-1.6.1: Product: Dell USB 7HK Keyboard
[ 3.135343] usb 2-1.6.1: Manufacturer: NMB
[ 3.135385] usb 2-1.6.1: configuration #1 chosen from 1 choice
[ 3.136426] input: NMB Dell USB 7HK Keyboard as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.6/2-1.6.1/2-1.6.1:1.0/input/input2
[ 3.136452] generic-usb 0003:413C:2001.0002: input,hidraw1: USB HID v1.00 Keyboard [NMB Dell USB 7HK Keyboard] on usb-0000:00:1d.0-1.6.1/input0
[ 3.137503] input: NMB Dell USB 7HK Keyboard as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.6/2-1.6.1/2-1.6.1:1.1/input/input3
[ 3.137539] generic-usb 0003:413C:2001.0003: input,hiddev0,hidraw2: USB HID v1.00 Device [NMB Dell USB 7HK Keyboard] on usb-0000:00:1d.0-1.6.1/input1
[ 4.135718] udev[393]: starting version 164
[ 4.980083] input: PC Speaker as /devices/platform/pcspkr/input/input4
[ 4.980195] Monitor-Mwait will be used to enter C-1 state
[ 4.980211] Monitor-Mwait will be used to enter C-2 state
[ 4.980225] Monitor-Mwait will be used to enter C-3 state
[ 4.980290] processor LNXCPU:00: registered as cooling_device0
[ 4.980935] processor LNXCPU:01: registered as cooling_device1
[ 4.981578] processor LNXCPU:02: registered as cooling_device2
[ 4.982144] processor LNXCPU:03: registered as cooling_device3
[ 4.982705] processor LNXCPU:04: registered as cooling_device4
[ 4.983211] processor LNXCPU:05: registered as cooling_device5
[ 4.983739] processor LNXCPU:06: registered as cooling_device6
[ 4.984255] processor LNXCPU:07: registered as cooling_device7
[ 4.998320] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input5
[ 4.998324] ACPI: Power Button [PWRB]
[ 4.998368] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input6
[ 4.998371] ACPI: Power Button [PWRF]
[ 5.121593] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 5.123228] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 5.412587] i801_smbus 0000:00:1f.3: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[ 5.455132] [drm] Initialized drm 1.1.0 20060810
[ 5.858909] nouveau 0000:01:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 5.858912] nouveau 0000:01:00.0: setting latency timer to 64
[ 5.859981] [drm] nouveau 0000:01:00.0: Detected an NV50 generation card (0x298200a2)
[ 5.860455] [drm] nouveau 0000:01:00.0: Attempting to load BIOS image from PRAMIN
[ 5.901912] [drm] nouveau 0000:01:00.0: ... appears to be valid
[ 5.901915] [drm] nouveau 0000:01:00.0: BIT BIOS found
[ 5.901917] [drm] nouveau 0000:01:00.0: Bios version 62.98.71.00
[ 5.901920] [drm] nouveau 0000:01:00.0: TMDS table revision 2.0 not currently supported
[ 5.901922] [drm] nouveau 0000:01:00.0: Found Display Configuration Block version 4.0
[ 5.901925] [drm] nouveau 0000:01:00.0: DCB connector table: VHER 0x40 5 16 4
[ 5.901927] [drm] nouveau 0000:01:00.0: 0: 0x00001030: type 0x30 idx 0 tag 0x07
[ 5.901929] [drm] nouveau 0000:01:00.0: 1: 0x00000200: type 0x00 idx 2 tag 0xff
[ 5.901932] [drm] nouveau 0000:01:00.0: Raw DCB entry 0: 02000300 00000028
[ 5.901934] [drm] nouveau 0000:01:00.0: Raw DCB entry 1: 01000302 00020030
[ 5.901936] [drm] nouveau 0000:01:00.0: Raw DCB entry 2: 04011310 00000028
[ 5.901941] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 0 at offset 0xD691
[ 5.903321] alloc irq_desc for 22 on node -1
[ 5.903323] alloc kstat_irqs on node -1
[ 5.903328] HDA Intel 0000:00:1b.0: PCI INT A -> GSI 22 (level, low) -> IRQ 22
[ 5.903404] HDA Intel 0000:00:1b.0: setting latency timer to 64
[ 5.954667] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 1 at offset 0xDA96
[ 5.974511] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 2 at offset 0xE392
[ 5.974521] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 3 at offset 0xE460
[ 5.986545] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 4 at offset 0xE716
[ 5.986556] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table at offset 0xE77B
[ 6.010444] [drm] nouveau 0000:01:00.0: 0xE77B: Condition still not met after 20ms, skipping following opcodes
[ 6.010452] [drm] nouveau 0000:01:00.0: 0xC4C8: parsing output script 0
[ 6.073747] [TTM] Zone kernel: Available graphics memory: 2022086 kiB.
[ 6.073754] [drm] nouveau 0000:01:00.0: 512 MiB VRAM
[ 6.094924] [drm] nouveau 0000:01:00.0: 512 MiB GART (aperture)
[ 6.094928] mtrr: type mismatch for e0000000,10000000 old: write-back new: write-combining
[ 6.095188] [drm] nouveau 0000:01:00.0: Allocating FIFO number 1
[ 6.099772] [drm] nouveau 0000:01:00.0: nouveau_channel_alloc: initialised FIFO 1
[ 6.100549] [drm] nouveau 0000:01:00.0: Detected a DAC output
[ 6.100551] [drm] nouveau 0000:01:00.0: Detected a TMDS output
[ 6.100552] [drm] nouveau 0000:01:00.0: Detected a DAC output
[ 6.100554] [drm] nouveau 0000:01:00.0: Detected a DVI-I connector
[ 6.100579] [drm] nouveau 0000:01:00.0: Detected a VGA connector
[ 6.283149] [drm] nouveau 0000:01:00.0: allocated 1440x900 fb: 0x40250000, bo ffff88011d011e00
[ 6.287040] [drm] nouveau 0000:01:00.0: 0x11C1: parsing clock script 0
[ 6.287423] Console: switching to colour frame buffer device 180x56
[ 6.288849] fb0: nouveaufb frame buffer device
[ 6.288850] registered panic notifier
[ 6.288852] [drm] Initialized nouveau 0.0.15 20090420 for 0000:01:00.0 on minor 0
[ 6.431399] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/input/input7
[ 7.753156] xhci_hcd 0000:02:00.0: WARN: short transfer on control ep
[ 7.753315] usblp1: USB Bidirectional printer dev 2 if 0 alt 0 proto 2 vid 0x03F0 pid 0x8011
[ 7.753330] usbcore: registered new interface driver usblp
[ 8.224317] Adding 7897080k swap on /dev/sda5. Priority:-1 extents:1 across:7897080k
[ 8.390633] EXT3 FS on sda1, internal journal
[ 8.470558] loop: module loaded
[ 9.620542] fuse init (API version 7.13)
[ 11.328183] r8169 0000:04:00.0: firmware: requesting rtl_nic/rtl8168e-2.fw
[ 11.425985] r8169 0000:04:00.0: eth0: unable to load firmware patch rtl_nic/rtl8168e-2.fw (-2)
[ 11.443344] r8169 0000:04:00.0: eth0: link down
[ 11.443349] r8169 0000:04:00.0: eth0: link down
[ 11.443567] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 13.174411] r8169 0000:04:00.0: eth0: link up
[ 13.174646] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 14.913531] Bluetooth: Core ver 2.15
[ 14.913589] NET: Registered protocol family 31
[ 14.913591] Bluetooth: HCI device and connection manager initialized
[ 14.913592] Bluetooth: HCI socket layer initialized
[ 15.246388] [drm] nouveau 0000:01:00.0: Allocating FIFO number 2
[ 15.250895] [drm] nouveau 0000:01:00.0: nouveau_channel_alloc: initialised FIFO 2
[ 15.350449] Bluetooth: L2CAP ver 2.14
[ 15.350451] Bluetooth: L2CAP socket layer initialized
[ 15.718116] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 15.718118] Bluetooth: BNEP filters: protocol multicast
[ 15.763432] Bridge firewalling registered
[ 15.844549] lp: driver loaded but no devices found
[ 15.970180] ppdev: user-space parallel port driver
[ 16.308111] Bluetooth: RFCOMM TTY layer initialized
[ 16.308114] Bluetooth: RFCOMM socket layer initialized
[ 16.308116] Bluetooth: RFCOMM ver 1.11
[ 16.309270] Bluetooth: SCO (Voice Link) ver 0.6
[ 16.309272] Bluetooth: SCO socket layer initialized
[ 18.366989] usb 3-3: usbfs: interface 0 claimed by usblp while 'usb' sets config #1
[ 18.367721] xhci_hcd 0000:02:00.0: WARN: short transfer on control ep
[ 18.790759] xhci_hcd 0000:02:00.0: WARN: short transfer on control ep
[ 18.791130] xhci_hcd 0000:02:00.0: WARN: short transfer on control ep
[ 18.791504] xhci_hcd 0000:02:00.0: WARN: short transfer on control ep
[ 23.136822] xhci_hcd 0000:02:00.0: WARN: short transfer on control ep
[ 23.137184] xhci_hcd 0000:02:00.0: WARN: short transfer on control ep
[ 23.137540] xhci_hcd 0000:02:00.0: WARN: short transfer on control ep
[ 24.072683] eth0: no IPv6 routers present
[ 25.643759] CPU0 attaching NULL sched-domain.
[ 25.643764] CPU1 attaching NULL sched-domain.
[ 25.643767] CPU2 attaching NULL sched-domain.
[ 25.643769] CPU3 attaching NULL sched-domain.
[ 25.643771] CPU4 attaching NULL sched-domain.
[ 25.643773] CPU5 attaching NULL sched-domain.
[ 25.643775] CPU6 attaching NULL sched-domain.
[ 25.643778] CPU7 attaching NULL sched-domain.
[ 25.708281] CPU0 attaching sched-domain:
[ 25.708285] domain 0: span 0-1 level SIBLING
[ 25.708288] groups: group ffff88000540fae0 cpus 0 (cpu_power = 589) group ffff88000544fae0 cpus 1 (cpu_power = 589)
[ 25.708297] domain 1: span 0-7 level MC
[ 25.708299] groups: group ffff88000540fbf0 cpus 0-1 (cpu_power = 1178) group ffff88000548fbf0 cpus 2-3 (cpu_power = 1178) group ffff88000550fbf0 cpus 4-5 (cpu_power = 1178) group ffff88000558fbf0 cpus 6-7 (cpu_power = 1178)
[ 25.708313] CPU1 attaching sched-domain:
[ 25.708315] domain 0: span 0-1 level SIBLING
[ 25.708317] groups: group ffff88000544fae0 cpus 1 (cpu_power = 589) group ffff88000540fae0 cpus 0 (cpu_power = 589)
[ 25.708323] domain 1: span 0-7 level MC
[ 25.708325] groups: group ffff88000540fbf0 cpus 0-1 (cpu_power = 1178) group ffff88000548fbf0 cpus 2-3 (cpu_power = 1178) group ffff88000550fbf0 cpus 4-5 (cpu_power = 1178) group ffff88000558fbf0 cpus 6-7 (cpu_power = 1178)
[ 25.708337] CPU2 attaching sched-domain:
[ 25.708339] domain 0: span 2-3 level SIBLING
[ 25.708342] groups: group ffff88000548fae0 cpus 2 (cpu_power = 589) group ffff8800054cfae0 cpus 3 (cpu_power = 589)
[ 25.708348] domain 1: span 0-7 level MC
[ 25.708350] groups: group ffff88000548fbf0 cpus 2-3 (cpu_power = 1178) group ffff88000550fbf0 cpus 4-5 (cpu_power = 1178) group ffff88000558fbf0 cpus 6-7 (cpu_power = 1178) group ffff88000540fbf0 cpus 0-1 (cpu_power = 1178)
[ 25.708362] CPU3 attaching sched-domain:
[ 25.708364] domain 0: span 2-3 level SIBLING
[ 25.708366] groups: group ffff8800054cfae0 cpus 3 (cpu_power = 589) group ffff88000548fae0 cpus 2 (cpu_power = 589)
[ 25.708373] domain 1: span 0-7 level MC
[ 25.708375] groups: group ffff88000548fbf0 cpus 2-3 (cpu_power = 1178) group ffff88000550fbf0 cpus 4-5 (cpu_power = 1178) group ffff88000558fbf0 cpus 6-7 (cpu_power = 1178) group ffff88000540fbf0 cpus 0-1 (cpu_power = 1178)
[ 25.708387] CPU4 attaching sched-domain:
[ 25.708390] domain 0: span 4-5 level SIBLING
[ 25.708393] groups: group ffff88000550fae0 cpus 4 (cpu_power = 589) group ffff88000554fae0 cpus 5 (cpu_power = 589)
[ 25.708402] domain 1: span 0-7 level MC
[ 25.708405] groups: group ffff88000550fbf0 cpus 4-5 (cpu_power = 1178) group ffff88000558fbf0 cpus 6-7 (cpu_power = 1178) group ffff88000540fbf0 cpus 0-1 (cpu_power = 1178) group ffff88000548fbf0 cpus 2-3 (cpu_power = 1178)
[ 25.708417] CPU5 attaching sched-domain:
[ 25.708419] domain 0: span 4-5 level SIBLING
[ 25.708421] groups: group ffff88000554fae0 cpus 5 (cpu_power = 589) group ffff88000550fae0 cpus 4 (cpu_power = 589)
[ 25.708428] domain 1: span 0-7 level MC
[ 25.708430] groups: group ffff88000550fbf0 cpus 4-5 (cpu_power = 1178) group ffff88000558fbf0 cpus 6-7 (cpu_power = 1178) group ffff88000540fbf0 cpus 0-1 (cpu_power = 1178) group ffff88000548fbf0 cpus 2-3 (cpu_power = 1178)
[ 25.708441] CPU6 attaching sched-domain:
[ 25.708443] domain 0: span 6-7 level SIBLING
[ 25.708446] groups: group ffff88000558fae0 cpus 6 (cpu_power = 589) group ffff8800055cfae0 cpus 7 (cpu_power = 589)
[ 25.708452] domain 1: span 0-7 level MC
[ 25.708454] groups: group ffff88000558fbf0 cpus 6-7 (cpu_power = 1178) group ffff88000540fbf0 cpus 0-1 (cpu_power = 1178) group ffff88000548fbf0 cpus 2-3 (cpu_power = 1178) group ffff88000550fbf0 cpus 4-5 (cpu_power = 1178)
[ 25.708466] CPU7 attaching sched-domain:
[ 25.708468] domain 0: span 6-7 level SIBLING
[ 25.708470] groups: group ffff8800055cfae0 cpus 7 (cpu_power = 589) group ffff88000558fae0 cpus 6 (cpu_power = 589)
[ 25.708477] domain 1: span 0-7 level MC
[ 25.708479] groups: group ffff88000558fbf0 cpus 6-7 (cpu_power = 1178) group ffff88000540fbf0 cpus 0-1 (cpu_power = 1178) group ffff88000548fbf0 cpus 2-3 (cpu_power = 1178) group ffff88000550fbf0 cpus 4-5 (cpu_power = 1178)
