h20 (Apr 26, 2001 04:12 p.m.):
mike (Apr 26, 2001 10:58 a.m.):
what about cas settings. i have an old 64mb pc100 dimm. should i have the cas at 3 or 2
thanks
h20 (Apr 26, 2001 09:20 a.m.):
I don't believe temps are the reason for the lockup. Could be improper BIOS settings, for peripherals, or CAS settings for RAM.
my setup:
celeron 566 @ 952; core voltage 1.50 @ 2.0; 128 ram, pc100; elsa 16mb video; alpha pep66, modified and lapped with 72 watt peltier and delta fan (can't hear you; speak up).
[img="http://"]
[img="http://"]Try using it with cas 2 first; then 3 if you need stability. Next try IO voltage of about 3.60 or 3.70 (if default is 3.50). Set PCI clock to 1/2 and AGP clock to 2/3. In addition, carefully add voltage to your cpu (for instance, increase from 1.80 to 1.85 - be very careful here; less is definitely more; dont go crazy in increasing voltage)
If temps are still too high, then take your trusty 12 gauge shotgun, load up with some rifled lead slugs, and put that puny assed cpu/comp out its misery.[img="http://"]
