SOLVED lockups!!!! what to do next pleasssssssse experts help
S
saint
Guest
hi all
my new system locks up(screen freezes no blue screens) at start up when i turn on the pc
it start in the black screen before windows (win me)
then when i restart in the windows logo and finally in windows even
if i dont do anything
also even if im staying in the bios menu it locks up.
after a few times like this it works fine
but again when i shut down the pc and boot it up again it locks up
i tried the following to fix the problem with no succsess:
upgraded bios to 1005a,replaced memory and hard drive(to new ons)
installed fresh windows 4 times, got all my cards out excepy my vid card
set the operation frequancy to standart in bios but nothing.
what can be wrong .please help
also before my specs my cpu 1.3 athlon b 200mhz is at jumperfree mod
and in bios it say 12.5x and cpu frequancy 100 is this ok or should i change
to other values if so what are they
amd 1.3b
asus a7v133-c
hyundai 256mb pc133
quantom 20.5giga ata/100 hard drive
nvidia gforce 2mx
sb live
realtek network adapter
fritz isdn card
cdrw and cd-rom\
via 4.32 drivers
please help me!!!!!!!!!!!!!11
What heat sink are you using that sounds heat related.
If you can get to bios go to the hardware moniter andcheck cpu temp,let system stay in bios a few minutes as this will heat cpu up.
I would also check the voltage. The Athlon needs 1.75v of power to operate normally, the Duron needs 1.5v. If it is a P4, the same 1.75v applies.
Also, do check the heatsink, make sure that the fan is rotating properly. You can tell just by looking at the fan, if you can see the blades turning 1x1 at a slow speed or the fan doesn't turn, thats not good, if you can't see the blades turning, thats good. Simplist way to put it.
Check your video card... my GeForce2 GTS can cook eggs, and I had alot of trouble when initally o/cing my processor. I also used to get screen freezes all the time with my Voodoo3.
This definately sounds like a cooling problem, and the video card should not be forgotten about when cooling a rig.
well i have a 300w power supplay and my vio voltage was 3.3 and stuck so i uped it again to 3.45 but still stucks
my vcore voltage is 1.75
i dont think its a heat prob because i have wbk-38
whatv else can it be
not sure if this is an viable option but you might trying using sisandra to bench parts of your system and if it locks up then you can atleast know which component is having issues
well thank you guyes
the problem was the psu.
i got another one and now it just works great stable
and runnig
i also switched the vio voltage to 3.3 just to be safe
also changed my multiplier to 10x133 insted of 12.5x100 and now i have more power and still stable
runs a little hot though cpu 57c idle 60 full load
mb 37c idle
but a small price to pay for stability
again thanks guys
