I haven't seen this in awhile, but when the AMD IMC first came into play, the high Ram voltage could and did damage some IMC's. Remember the IMC was made up of part of the NB that used to reside on the mobo. Way back then we said the IMC was damaged since the ram worked fine in another motherboard but the ram gave issues in the AMD board with IMC that had had high Ram voltage given to it. I think the term used was back EMF causing the damage.
Scratching my head trying to remember all the surrounding circumstances. Mainly trying to remember when the AMD started to use or call out a dual power plane as in use. What we found to do was to use more Vcore than necessary to run the cpu mhz but the extra voltage saved the IMC. You got to remember this was a few years ago now.
When you look at most AM3 and AM3+ boards, you will see a memory spec of 1.5V in most I have read lately. NO I have not read every AMD motherboard spec for memory manufactured in the world. Just saying 1.5V ram volts seems the standard today in AMD world.
I am looking toward PD and had to make a NewEgg order the other day and ordered me some 1.5V ram because " I " did not want to take a chance on hurting "my" IMC. I still have quite a bit of older DDR3 but it takes 1.65V in general.
So when we type into a forum whee gawd himself only knows who is reading, we need to almost always err on the side of caution. IMO only. YMMV.
RGone...ster.
