AMDGuy (Jun 06, 2001 10:24 p.m.):
I found 3000 grit at Sherwin Williams paint stores for $1.00 a sheet. This is the finest wet dry available. I lapped my BECOOLING copper block all the way up to 3000. I then test mounted it with artic silver 2 to see if it actually did cause a problem being so smooth and it didn't. I mounted it, then removed it and looked at how the artic silver 2 was dispersed. There was a perfect rectangle of artic silver 2 on the block.
outhouse (Jun 07, 2001 01:01 a.m.):
Good job lapping I know what you mean at 1500 i'm getting good results out of a cheap HSF but i think if 600 will work the same i think i'll save the extra hour of lapping, the main reason i have replied is i'm hoping maybe someone else reading this could give it a try and see what the temp difference is between the two 600 or 1500 and up, anyone getting ready to lapp please give this a try and let us know your results this has been done before but it all come down to Celcius how low can you go![]()
