It was ordered. When I ordered (almost 2 years ago) i really didn't know that much about modding computer cases (yes I did buy it, but modified it a little). I bought it from 3DCOOL.com, but it came with two 92mm blow holes on the side pre-cut. If you are looking for a really solid case, mabey one that already looks good then check out
www.3DCOOL.com. They are a good place to get stuff. Other than that it is just an ANTEC case with the front slide down/up face plate. It is a full-server tower. I really like it since all of the Hard Drives (if you use an adaptor to mount them into the CD-ROM bay), and CDROMS and Power Supply are seperate from the rest of the system). It measures (in inches) 24(h)x7.5(w)x17(front to back). These are outside measurements.
http://www.3dcool.com/?module=product&sku=tornado3000
Check out that link to see the exact computer case I bought. Read about it carefully. These guys "REALLY" know what they are doing when it comes to cooling down the computer. The pic gives you a good inside view of it. Now looking back, you can buy the origional case and Mod it your self for cheaper. I can't find it yet but I will find out where you can get the plain old case. If you got the money, buy this case, YOU WILL LOVE IT.
Hope any of this helps.
