Haha, I would but it doesn't fit (hits the "Thermal armor" on the sabertooth ). This cooler does the job well, but its absolutely massive. I honestly have so much airflow in this case (7 140mm fans work wonders) temps are not even close to an issue.
With that, I ordered an AIO watercooler, which will actually solve MOST of my issues. I can move the GPU up to the first PCIE slot (instead of the bottom one), which gives me clearance over the psu, allows me to use the 5 bay drive cage (I think? Ill make it work if its not supposed to fit), so I can miss 2 HDD's instead of 4 (probably just put a 5.25" hot swap bay in), and I dont have to worry about "sucking hot air" from the GPU.
