When I was reading around the internet for information on bilge pumps, every boating site recommended Rule. I figure that hundreds of preppy yachters can't be wrong.
As for running it 24/7, I broke it in for 11 hours at 12 volts, and it was fine. But because I'm going for silence, and not performance, I rewired mine for 5 volts, and I ran it for
four days without a hitch. The water never so much as got warm. Someone warned me that they are not designed to be run 24/7, but I haven't had any problems. If you're concerned about running it all the time at full 12VDC, I'd suggest just lowering the voltage or reversing the leads (reversing the leads on a Rule pump runs it at 20% capacity). But I don't think it's an issue.
Heh
fishie pumps. As far as I can tell, the Rule pump only turns the impeller, so I figure that with the exception of the motor, that is the only moving part. If you check out
Rule's homepage it says that it is lubricated by the water, which is a plus.
When I was breaking the pump in, and testing it, I had it hooked into my 250 watt generic POS power supply. Yellow wire for +12, red wire for +5. I don't have any other method for giving it 12VDC, so I just used tap splices with the corresponding wire.
Reassured?
