- Jan 13, 2005
I need to change my computer set up, i'm going to convert a closet that had a bunch of crap in it to a computer cubby
Problem is my current case is too big so i am looking for recommendations because i cant find what i am looking for.
i'm looking at full size atx motherboard case no need for rgb or glass panels but i wouldnt avoid it if it fits the bill
my needs are as follows:
Good Airflow
Quiet (adding sound dampening mats later is ok, dont know what brands to use)
fits a 360mm Rad
no longer than 24 inches from front to back
i had considered swapping everything to a matx board but in the long run that will be more expensive than just getting a case
this will be long term temporary as i'll want to go back to the case i have currently after i, or we (depending on future outcomes) move into a new place.
this is closest to what i have that i can find online, mines a 6 and not a 5 but its only a little taller the rest of the dimensions are the same
https://www.amazon.com/Silence-Sens...d=1609967525&sprefix=nanoxia+d,aps,233&sr=8-1
Good Airflow
fits a 360mm Rad
