looking for a RP-SMA antenna
mbentley
Gloriously Lead, Overclockix Chief Architect
Indianapolis, IN
okay, so i have a linksys wmp54g wireless pci network adapter. now the problem: my antenna for broke because it was a cheap piece of plastic. now, it still works okay, but i would rather have a working antenna that is 100% functional (maybe a better one too). i have contacted their tech support and they said they do not sell antennas at all so i am curious if anybody knows of any online vendors that sell antennas for something hopefully less than $30 or $50 if it is supposed to be a powerful antenna...
or go to www.fab-corp.com and click on "antennas omni" on the left. you should find about 7 products down, 5.5 dbi R-SMA/R-TNC rubber duck antennas for $19.50, $10 3-day shipping. 5.5 dbi is about 3db higher than the stock antenna and i think that means it doubles your range. imo a cleaner look than the separate antenna that bobby linked:)
ah thanks you guys... i didn't even think to check newegg for one... now just picking the one i want... hmm... :D
