- Jan 15, 2021
Hi guys
The Arctic Freezer 13 Pro cooler on my i7-2600K is broken, the plastic on the mounting plate split so the heatsink will not firmly screw down on one side. I never overclocked this PC when using that cooler, but I want to overclock now
I did a quick google search for a suitable replacement and I found a couple of heatsinks in the £30-£40 range on ebay. These are the Cryorig H7 and the Cooler Master Hyper LED Turbo - with the Cryorig being about £10 cheaper. From a quick read the Cryorig even with the single fan is better than the Hyper LED Turbo with two fans. Though this seems to be a bit subjective/open to opinion. Both these were recommended in various places for i7-2600K overclocking.
I also looked at some cheap AIO coolers like this one https://www.ebay.co.uk/itm/240mm-Ai...5&algv=default&_trksid=p2047675.c100008.m2219 This is in the same price range and I found some good reviews but I don't think that would fit in my Cooler Master ATX case as I can't fit two 120mm fans in the top as it is - the rear would be obstructed by the USB connectors on the motherboard. With the exra thickness of an AIO radiator and front fan would be obstructed by the RAM.
So I'm thinking of getting the Cryorig - but if anyone has any better suggestions under £50, or there are very good reasons to pay a bit more, then I would be happy to hear them. I'll consider new or used.
One problem I had with the Arctic Freezer, the Ripjaws Z DIMMS on my P8Z68-V mobo obstruct the cooler fan so I had to mount it backwards. I would like to replace it with something that actually fits this time.
TIA
Rich
TIA
Rich
