- Jan 9, 2006
Having a bit of trouble since 92mm seems to be less popular these days. I ran into a few sleeve fans and some deltas that do 4800rpm but the really fast ones will have trouble running at slower speeds. it would be nice to be able to idle under 1000rpm if possible at low temps but it's not 100% necessary since I can set the video card to 0 rpm at under 40c if I must. Low power draw is good since it'll be nice to be able to run off the card header but I'm looking into a custom cable that may stop power limit from being an issue. Thanks!
EDIT: This would be perfect if it was around 2800rpm and half the power draw https://www.newegg.com/Product/Prod...ta fan&cm_re=delta_fan-_-35-213-014-_-Product
