- Jan 19, 2002
- Groton, CT
Do any of you know of any vendors that sell Blue leds that run on low voltages such as 2.0vdc. All I have been able to find are ones that run on 3.6-3.8vdc.
Arkaine23 said:I've got one for my power led, but I ran it off a molex with a resistor.
Tbird man said:or if you wantes to get complex you could use a low volt solid state relay that closes at 2v to run the led from the +5v line with resisterswell just my two hundredths of a dollar
Tbird man said:well the lowest voltage i could find was 3vdc (not to say they aren't out there) i thnk your best bet would be to just run the 3.8v @ 2.0v and not get the full brightness.
scoobydoo said:You could take a white one and color it blue with a magic marker, or get some of these http://www.partsexpress.com/pe/pshowdetl.cfm?&DID=7&Partnumber=070-086
I am in the same situation, I have a 3.7V Blue LED and tried hooking it up to the power LED and it was barely glowing
I wonder what would happen if I hooke it too the 5V? Would it handle the extra 1.3V or just blow up?
Iron Hawk said:
What I am trying to do is attach the blue leds to the cdrom drive so they flash when the drive is reading. and for that i need a 2v led.
FragSyndrome said:
