looking for something like proxmox
95blackz26
North Brookfield, MA
ok i want to use something like proxmox but would rather pay upfront for a license..i like the ability of using the browser to enter the proxmox setup..
if you have experience with something like this i'd like to hear from you.
95blackz26
95blackz26
i'm running windows server 2012 r2 as a base right now , i'm using that as a file server but i want to setup virtual machine for specific uses and would like the ability to remote access them.. vmware workstation is $250 right now.
Janus67
Benching Team Leader
Okay, so you are looking for a type-2 hypervisor, not a type-1 (bare metal one). Proxmox is a bare metal hypervisor which is why I made those suggestions. ESXi is free (up to 2 cpu sockets and 64gb of RAM IIRC) as is Proxmox actually, I thought. Obviously you have HyperV built into your OS, but it doesn't have a web interface for management, you'd either need to use the local hyperv installation to manage or can install the RSAT tools on another machine if you wanted to do it remotely.
95blackz26
95blackz26
i'm moving this coming weekend so i won't have any time to put into this. i have a Intel S2600CP2J with 2 E5-2670's and 64gb of ram. just need to get a case for that which will probably end up being this CHENBRO SR11169..right now i'm using a poweredge t110ii which i have a 1230v2 and 32gb ram..ram isn't an issue right now but even with running the VM's at 2 cores each you can feel the pain.
