- Jan 12, 2001
- Kansas, USA
- Thread Starter
- #21
My research this morning has revealed the card I bought is called "non A" (the GPU is a 300 where the rest have the 300A). The non A (lower power limit) cannot be flashed with a BIOS from a 300A card. Once you do a google search, you'll find lots of people that tried and failed. Currently, you would have to find a another non A card that has the higher power limit (which is not allowed by Nvidia because they have to approve all BIOS updates) or hack a non A BIOS to allow a higher power limit. Here is a partial FAQ I found that explains this a bit more.
Yeah, I keep waffling back and forth. I've seen several posts that suggest that the really high voltages really don't help much. Honestly, I still like benchmarking, but if I don't get that last 1% of performance squeezed out, I guess that's not the end of the world. I said the "A" version is $200 more, well I rounded up. It's really $180 more (but figure in a few gallons of gas and turnpike tolls and it's close to $200 total. They do have an open box (XC version) for only $50 more than what I have invested. I have bought open boxes before, but it's a bit risky with high end vid cards. You never know what was done to it or why or why it was returned (probably because it didn't OC as high as the purchaser wanted).
EDIT: I guess maybe I'll think about the vid card situation for a while this morning and make a decision later today. I probably should do a bit more research. I'm having trouble believing nobody has found a solution yet.
Question: What does Non-A mean?
Answer: There are two GPU variants: TU102-300 (1E04) and TU102-300A (1E07). Factory overclocking is prohibited on the former, it has a boost of 1545 MHz and a maximum power limit of 280W. The latter chip has varying factory overclocks and power limits up to 450 W, flashing a 300A based BIOS onto a 300 GPU and vice versa is not possible. Manual overclocking is possible on both.
Question: How do I know if I have a 300 or 300A card?
Answer: Check the list above, but it may be incorrect as the early batches of the ASUS Turbo card had the A chip, recent reports indicate later batches are the correct 300 chip since the card was always advertised as not having a factory overclock. To be certain, check the Device ID in the main window of GPU-Z, if it shows 1E04 it is the 300 chip, if it shows 1E07 it is the "binned" 300A chip.
Question: How do I know what power limit my card has?
Answer: In GPU-Z, click the Advanced tab, then General and finally choose NVIDIA BIOS, under the Power Limit section you will see Default and Maximum.
Question: What does the power limit actually do?
Answer: Several years ago we had full voltage control, then NVIDIA introduced a power and temperature limit. Once a 300 card reaches its maximum 280W power usage it will restrict the voltage: for instance, my 280W card could not exceed 0.913v running a game in 5K resolution, this meant it could not reach a higher than 1860MHz core clock although the GPU has a hard limit of 1.093V, therefore it's far from its true potential.
Its a $200 price difference?!! Wow....... I was thinking maybe $50... doesn't seem worth it at that cost, and especially the time involved.
