- Feb 6, 2001
Looking for those familiar with MSI i815e 6337 mobo, I got questions about oclocking
Hello,
I have the MSI i815e 6337 Lite mobo. I really like it but have been having some challenges with overclocking my processor, a PIII-700 that ran at 875 on my BE6-II mobo.
I installed Fuzzy Logic II software that is an auto overclock utility prog, when I select the "auto" function it adjusts the cpu to the highest speed using default voltage however I can't figure out how to save the settings. When I try to do it manually the system locks up and I get an alarm going off when I exit bios and reboot.
The board uses half agp divider and it also shows you what your pci speed is as you increase the buss speed. I am stumped as how you go about overclocking the cpu manually in the bios.
hereandgone
Hello,
hereandgone
