Looking to build AMD puter any suggests for mobo...Thanks
Epox 8k7a is a great board. It has some of the highest benchmark scores out there. Im running 1333 athlon at 150 fsb 1500mhz , no probs
Well, for what it is worth I have 1 ABIT KT7's, 2 ABIT KT7A's, and 1 ASUS A7V. I personally favor the ABIT board. My one word of advice would be to make sure that you get a clean boot prior to adding pci cards and/or overclocking. Hope this helps!
NyTe (Jun 24, 2001 05:36 p.m.):
what a ?...every1 that loves their board is going to recommend it...LoL I had a couple probs with my board to begin with ( just updates of VIA KT133a ) but i love my KT7A-RAID
Not everyone!! I'm running a FIC AD11 and I will not recokmmend it to anybody who wants to OC as it becomes very unstable if you try to up the FSB, so it leaves you with only the multiplier! Otherwise it does do good benchmarks apart from 3DMark2001. I can bearly beat 2000 score with a Geforce2Pro on it. That's after I loaded the latest Bioses, drivers and OCed the CPu to 1580 and the GPU to 250/400!!
If you dont need Raid then look at the ABIT KT7-E.
Also read it here-http://www.viahardware.com/abitkt7e.shtm
I have NOT had any problems with it at all !!!!
And it's a little less $$ then the KT7-A
