This is what I have;
Northwood 1.8ghz p4 SL66Q Costa Rica
ATI Radeon 9600 PRO
ASUS p4pe-x MB bios version 1004
Antec power supply= 400 watt smart power
120mm Zalman cpu fan CNPS7000A (HUGE)
Maxtor 80gb hard drive (1) 256 mb Infenion pc 2300 ( yes, that is what cpu-z says, 2300)
(1) 128 mb Samsung pc2100
Temps are as of PC Probe;
CPU = 33 C
MB = 23 C
My system is overclocked to 2377 mhz ( FSB=132)
cpu voltage is auto set at 1.58 volts
everything else is at default setting
My problem is that a couple days ago I set it at FSB 133, windows booted fine, ran 3dmark 2001 which was 10,237. 10 minutes after benchmark my pc probe alarm sounds and it showed cpu fan speed =0 and case fans speed =0 while I could still hear them running. I shut the computer down and rebooted at 132 FSB.
Since then my 3DMark 2001 benchmarks have been 9,227 or a little less.I am a newbe at o/c but I studied alot on the subject.
I have run SisSoftware Sandra for 2 hours without a single problem. At peak testing my CPU temp never went above 46 C.
Everything is running great but what happened to my 1,000 pts on 3DMark 2001?
Any help will be highly appreciated.
Galador
ATI Radeon 9600 PRO
CPU = 33 C
MB = 23 C
Galador
