- Dec 23, 2004
- Sandy, UT
First off, I must say that I'm quickly losing hope. Let me give you all some background. My specs are in the sig. Everything has been running perfectly stable and cool for a year now at those speeds. (Mind you I keep stock speeds when I'm not gaming.) Anyhow, in the past year, I've had data corruption on all my hard drives 3 times, with the most recent occurance being a little over a week ago. The first two times, the 4 HDs were in RAID 0 with an old Silicon Image 640 PCI controller. I lost about 80% of the data each time. After being sick of losing that much not once, but twice, I took, the drives out of RAID to run them as single drives. I even bought a new Highpoint Rocketraid133 controller card because I didnt trust my SiI 640 card with it's notoriously bad reputation.
While all of this data loss is most annoying, there's more to the story. A few days ago while playing Doom, I paused to plug in a speed control knob to my cpu fan. It seemed pretty routine. I was careful not to short anything as I did it, but as I plugged it in, all of the LED fans dimmed and slowed for a moment, and then the entire computer shut off completely.
At first, I thought I had bumped the heatsink on the cpu (though if I had, it was not hard at all. And the heatsink still appeared to be seated fine.) But to be safe, I reseated the HS/F and reapplied thermal paste before I turned the comp back on. I immediately checked temps and voltages, all of which were normal. However, after I rebooted and attempted to load windows, I started getting random BSoDs each time I restarted.
IRQL_NOT_LESS_OR_EQUAL
DRIVER_IRQL_NOT_LESS_OR_EQUAL
PAGE_FAULT_IN_NONPAGED_AREA
BAD_POOL_HEADER
PNP_DETECTED_FATAL_ERROR
DRIVER_CORRUPTED_MMPOOL (According to MS support this stop error is "Disasterous" and caused by corrupt memory, but they do not specify system memory, bois, HD, or any sort of cache.)
I also recieved BSoDs telling me to run chkdsk /f, telling me that disk.sys and cdrom.sys were corrupt.
Most recently, I can no longer even boot as far as before to the point where I would get the BSoDs because windows stops with the error that \windows\system32\config\system is missing or corrupt.
These BSoDs would seem to indicate that it is a driver issue, but the fact that they are getting progressively worse makes me think not. I had not modified any drivers at the time. I have been thinking it is most likely either the mobo or psu. The mobo could not be properly handling IRQ assignments or the psu voltage could be fluctuating. Here's what I've found.
I've swapped every part except the mobo (including the vid card, both sticks of ram, the cpu, the HD's and the optical drives.) Of those parts, all were fine except the PSU. When I swapped the out the Antec 480W with another cheap Rhycon 550W, the BSoDs went away and windows loaded. I wonder if I'm putting too much load on the PSU or if its just bad. I haven't yet successfully gotten the computer to boot on another mobo to verify if that is also an issue. The spare mobo doesn't seem to be booting from the HDs connected to the Highpoint IDE controller, yet I normally use another Promise TX2 controller in that spare mobo, so I am familiar with the required settings. I have tried both controllers.
If it is indeed a psu issue, I'm am not convinced that is the only problem. Why would I only get errors as windows boots? Why not sooner? For that reason, I'm more inclined to think that it is a mobo IRQ handling issue because the mobo handles the IRQ assignments as windows boots. (And fluctuating power from PSU could also be an issue there. Yet remember I found all the PSU voltages to be normal.) There are too many inconsistancis. I'm lost as to what to do from here. To make matters worst, since that \windows\system32\config\system file is corrupt, I can no longer get far enough in the windows loading process to see if the BSoDs have been corrected as I swap parts.
I tried booting with another hard drive that has windows xp installed and configured for a VIA chipset instead of the nforce2 chipset, but got another chkdsk /f BSoD. That error may be expected. I dont know. I also tried booting to the recovery console from an XP CD and got the same BSoDs. That makes me think the errors were NOT HD corruption, at least originally. As for now, there is definately corruption.
The problems I experenced the last 2 times I experienced the data corruption were very similar to this- similar BSoD messages, and chkdsk errors. Formatting did fix the issue, but this time seems different. Why does it keep happening? How can I pinpoint the source of intermittent issues? I'm ready to toss the HDs, mobo, psu and buy new ones, though I really can't afford to do that. If anyone has any ideas, I'd desperately like to hear them. Much thanks for taking your time.
BAD_POOL_HEADER
