- Jul 16, 2005
- Ontario, Canada
The point is not how prolific is it, the point is it happens. Would you rather no one ever bring it up? It is naive to think that by not knowing about it it will never be an issue.
I have not seen anyone say, OMG dont get a P55 because they blow up!! Seen lots of posts saying, if you are getting a P55 try and get one with a LOTEs socket.
Also sockets are not hte only thing to blow up on P55 either. Even a build overvolting of 1.4volts was enough to pop a FET on the Biostar P55 just like happened to some people on the AMD boards that were supposedly 140W compatible.
It lets you know... hey, going to OC make sure your FETs are sinked(obvious to some not to all) same with the possibility of OCing on P55, you are far more likely to over amp the socket wit h a foxconn built, over a LOTES.
Sorry, why would having that information out there be bad? You think Foxconn is going to go out of business over it? If they went under prices would soar from the vacuum they made![]()
I think you miss'd my point, information is great but when ppl take a few isolated cases and make it seem more than what it is, it is no longer information it is now gosip.
I have been on 3 forums where the X58 fanbois bash P55 for bad sockets and "your system will fry" comments are a plenty. Are they educated about the issue...no they take a quick look at threads, read the first post and look at a few pics, then they go out on there holy crusade and spread the hype.
miss-information is worse than none at all imo......
