- Jan 19, 2001
Hello,
I've noticed the last few days a pretty significant noise from my computer. I initially thought it was my HDD getting ready to go out, but upon closer analysis it turned out to be the Power Supply and further more, I believe the fan in the power supply. The reason I say this is because I can change the pitch of the sound by pressing the fan grill against the fan while the sound/vibration is occuring. I took the power supply apart to see if anything was loose and further tightened down any and every screw, then threw it all back together and it seemed to take care of the problem but then the horrific noise reared its ugly head again so this time I put thin cork stickies between the fan and the power supply box and the power supply box and the computer frame. This seems to lessen the occurance of the vibration but its still there!
Is my analysis correct that it is the power supply fan? If so then is the fan going out?
If not is the power supply going out? Does anyone know how to fix this problem? Thank You for your posts
