- Jul 9, 2011
- NC
The plan so far is to stack ITX motherboards and power them with PicoPSUs, which will be powered from an ATX PSU.
I thought about getting 24pin splitters to be able to run them all from the ATX PSU, but the cost ended up being more than going with PicoPSUs. All 4 systems running shouldn't use but around 60-90 watts from the ATX PSU.
In total the plan is to have 3x N3150 motherboards and one J1900 system.
The J1900 system will remain my router/firewall and the other three should (over time) become an openstack setup. (1 controller and 2 compute nodes)
Probably gonna make ducting (aka case) around the stacked motherboards so I can use a few fans to blow air across the boards even though they are all passively cooled. For some reason no one makes a case that does what I want here lol.
I do wish the N3150 boards had dual nics but I havent found anything in that power/price range that does.
