So did you find ant ram online that will fit your needs?Yes, they run as fast as they can (corsair vengeance ram don't oc much above stock speed if at all)
3200mhz 16-19-19-36 was not strable so stock speed as shown in #19
I don't think you are going to get the kit & speed you want less the $150.That is 3200mhz
Here is one it has the right spped but its not 64gigs.Like I said you are not going to that speed kit less then $150.
I thought you wanted 64gigs?????just a little under 160 euros for 2 kits of G.Skill Ripjaws V Black DDR4 4000MHz 2x16GB (F4-4000C18D-32GVK)
They would have to be cl18 to have the right price = just about the same speed as 3200mhz cl 16 ramI found these I have them I think they are low enough.
G.SKILL Ripjaws V Series 64GB (2 x 32GB) 288-Pin PC RAM DDR4 3600
I wish you the best of luck.They would have to be cl18 to have the right price = just about the same speed as 3200mhz cl 16 ram
You may have some struggles running that speed with 4 sticks as it's more stress on the IMC.2 kits is 64gb
